Thread: Starting a Kaman K-MAX helicopter - GIF
  2. The Following 7 Users Say Thank You to ToolTalkBot For This Useful Post:
    albertq (Mar 3, 2026), emu roo (Mar 3, 2026), Floradawg (Mar 3, 2026), mwmkravchenko (Mar 3, 2026), nova_robotics (Mar 3, 2026), rlm98253 (Mar 8, 2026), tonyfoale (Mar 12, 2026)
    Aug 2021
    Cape Town SA
    albertq's Tools
    An interesting helicopter type and one of its unique features is the way it controls the rotor blade pitch.
    The Kaman K-MAX helicopter uses a unique servo-flap rotor control system rather than direct mechanical pitch links, eliminating the need for hydraulic flight control servos. Small, pilot-controlled flaps on the trailing edge of the wooden rotor blades move to create aerodynamic forces, causing the main blades to twist and change pitch. Aviation Stack Exchange +2
    Key details of the K-MAX pitch control mechanism include:
    • Servo-Flap Control: Small trailing edge airfoils, located about 75% of the way to the tip, change the angle of attack of the main blades. When the flap moves down, the blade pitch increases, and vice-versa.
    • Reduced Control Forces: Because the aerodynamic forces on the flaps drive the blade pitch changes, the pilot's control inputs require much less force, allowing for a robust, non-hydraulic system that simplifies maintenance.
    • Internal Control System: Push-pull tubes travel down through the hollow rotor mast to the hub and then along the blades to actuate the servo flaps.
    • Intermeshing System: The K-MAX uses two side-by-side rotors that mesh together. The system applies differential collective pitch to control yaw and differential cyclic for pitch/roll control. Aviation Stack Exchange +4
    This design makes the K-MAX highly effective for external load operations, as the system provides direct, responsive handling without hydraulic lag.
  4. The Following 4 Users Say Thank You to albertq For This Useful Post:
    emu roo (Mar 3, 2026), Floradawg (Mar 3, 2026), Frank S (Mar 3, 2026), tonyfoale (Mar 12, 2026)
