Results 1 to 6 of 6
Thread: Stone block cutting machine - GIF
    nova_robotics (Feb 20, 2023), that_other_guy (Feb 25, 2023)
    Dec 2018
    I guess they are not worried about lung damage.
    Sep 2018
    nova_robotics's Tools
    Quote Originally Posted by 2SSRedline View Post
    Or ankles.
    Mar 2018
    Hoosiersmoker's Tools
    What is that stuff? It looks like foam or something. Limestone? Sandstone?
    "The man who views the world at 50 the same as he did at 20 has wasted 30 years of his life."
    - Muhammad Ali
    Jul 2020
    Malta
    johncg's Tools
    It is limestone. The cubiod shaped stones are used in building houses, churches and in the past fortifications. It can be shaped or sculpted in any shape needed. Bigger stones are sculpted into statues and monuments.
    Stone block cutting machine - GIF-malta-island-gozo-top-attractions-victoria-medieval-hilltop-city-citadel.jpg
    Attached Thumbnails Attached Thumbnails Stone block cutting machine - GIF-1000_f_303515609_zhuwubqxgsjf8nf6t01nuf5lynm269gw.jpg
  7. The Following User Says Thank You to johncg For This Useful Post:
    Jon (Feb 22, 2023)
    Sep 2021
    bigal001's Tools
    Indeed, these limestone blocks are "harvested'' from quarries; measuring 27" x 9" x 11". I know this particular fellow, he is from Gozo, owner of NTG Contractors, the quarry is overlooking the famous Dwejra Bay with the Fungus Rock, ex Azure window & inland sea...
    The dust is not much of a problem, as it is quite damp when being cut & settles easily. Blocks that size weigh about 150 lbs each,
    As mentioned, custom measurements are ordered, and in this size up to 6 foot lengths are ordered by the Master Mason for particular uses, eg Lintel blocks to span over door-ways. Houses are built using one 9'' block, but larger buildings use 2 thicknesses thick walls to support larger concrete-slab roofing.....
  9. The Following User Says Thank You to bigal001 For This Useful Post:
    nova_robotics (Feb 26, 2023)
