1 Attachment(s)
STORAGE FOR COMMONLY USED DRILL BITS
I wanted to have quick and easy access to the drill bits I most often use so I put together this shelf which hangs on the wall next to my drill press. I have my Forstner Bits, Common Twist Drill, Brad Point, and Spade Bits as well as a few countersinks, drivers and chuck key within arms reach. The Spade, Twist, Brad Point and misc bits sit it movable drill bit stands which keep them in order by size and so that they can be moved to the bench if I'm using a portable drill. Easy to find and to put back when I'm done so I can find them again
