Results 1 to 4 of 4
Thread: Straight flute gun drill - GIF
    Altair's Avatar
    Straight flute gun drill.
    Homemade button rifling press - video
    Naval gun rifling cutting bit - photo
    2000 Tool Plans 186 More Best Homemade Tools eBook
  2. The Following 4 Users Say Thank You to Altair For This Useful Post:
    clydeman (May 24, 2023), johncg (May 25, 2023), Resident114 (May 24, 2023), that_other_guy (May 24, 2023)
    Jul 2014
    France, Brittany !
    Christophe Mineau's Tools
    These Gun drills are the exact same we use on hard wood , ebony, boxwood ... in woodwind instrument making.
    In this case we use compressed air instead of collant.
    I think I have a tool already showed here explaining my setup to do such boring operations and the copler I made to drive compressed air in the shaft.
    186 More Best Homemade Tools eBook Homemade Tools eBooks
    Cheers !
    Christophe
    Facebook : La Belle Note
  4. The Following 3 Users Say Thank You to Christophe Mineau For This Useful Post:
    Altair (May 27, 2023), bruce.desertrat (May 28, 2023), desbromilow (May 27, 2023)
    Supporting Member schuylergrace's Avatar
    Sep 2020
    Mesa, Arizona
    Is there any benefit to this drill configuration (the cutter arrangement, not the cooling) beyond that it appears to be really good at clearing chips from a deep hole. That's a plenty good reason to use one in some situations, like I don't know, making a gun barrel bore. But I wonder if there are other ways it excels and might be useful. Any drawbacks? I assume it probably cuts less aggressively.
    For topical application, only. Not to be taken internally or used in com-
    bination with other drugs or alcohol, except as directed by your shaman.
    Do not operate heavy equipment, unless you actually know how to.
    piper184's Avatar
    Jul 2016
    piper184's Tools
    Supposedly the main advantage to a single cutting edge is that it does not have a tendency to wander sideways like a standard drill with two cutting edges.
    As long as the bore is straight, it can be reamed to final size later. I think originally they used a spoon type bit to drill out the bore. I find this kind of work on a lathe fascinating. Doing it by hand even more so.
    186 More Best Homemade Tools eBook 2000 Tool Plans
  7. The Following User Says Thank You to piper184 For This Useful Post:
    schuylergrace (May 28, 2023)
