13 Attachment(s)
Strong 813 test socket
Hi all!
I built this socket from 12mm thick Teflon round rod. Screws are M3 stainless.
The purpose is to have a strong, stable, accurate and well insulated test socket.
I needed something able to resist to temperature and voltage, above all the socket have to keep locked the tube even in vertical position with no yielding.
Material needed:
- 1,5mm Teflon slice, 70mm dia
- Heptagonal pattern
- Spring contacts x7
- M3x10mm screws and nuts x7
Equipment:
- Lathe
- table drill
- Bits and basic equipment
Attachment 19977 Attachment 19978 Attachment 19979
Attachment 19980 Attachment 19981 Attachment 19982
Attachment 19983 Attachment 19984 Attachment 19985
Attachment 19986 Attachment 19987 Attachment 19988
Attachment 19989
Thanks rendoman! We've added your Test Socket to our Electrical category,
as well as to your builder page: rendoman's Homemade Tools. Your receipt:
<div id="blocks">
<div class="block b1 pngfix">
<div class="bimg">
<div>
<a href="http://www.homemadetools.net/homemade-test-socket">
<img src="/uploads/205504/homemade-test-socket.jpeg"/>
</a>
</div>
</div>
<div class="title">
<a href="http://www.homemadetools.net/homemade-test-socket">Test Socket</a>
<span> by <a href="http://www.homemadetools.net/builder/rendoman">rendoman</a></span>
</div>
<div class="tags">tags:
<a href='http://www.homemadetools.net/tag/socket'>socket</a> </div>
</div>
</div>
</div>
