Results 1 to 4 of 4
Thread: Sunk Bench Stop / Bench hook
    Jul 2014
    France, Brittany !
    Christophe Mineau's Tools
    Hi,
    I eventually made the traditional bench stop I've been needing for a long time and that I never took time to make so far...
    It's old style, a sturdy vertical square post that goes through a mortise traversing the bench top.
    My addition to the tradition is, instead of making the claws with an array of pointed nails, to use a scrap piece of band saw, screwed at the end of the post. I re-filed someawhat the teeth in order to get more grip.
    I also cut a rabbet at the end of the post to insert the blade, so that it is backed by wood for supporting the planing strokes.
    The mortise was made with the router and a simple template temporary nailed on the top of the bench.
    I made a low profile extension to the mortise just to sink the teeth of the blade, when not used.
    The post is made of beech wood.
    Cheers !
    Christophe
    Facebook : La Belle Note
  2. The Following 9 Users Say Thank You to Christophe Mineau For This Useful Post:
    baja (12-09-2020), CharlesWaugh (12-08-2020), DIYer (12-05-2020), Home-PC (12-11-2020), Jon (12-09-2020), Priemsy (12-13-2020), rlm98253 (12-08-2020), toeless joe (12-08-2020), Tonyg (12-09-2020)
    Thanks Christophe Mineau! We've added your Bench Stop to our Workbenches category,
    as well as to your builder page: Christophe Mineau's Homemade Tools. Your receipt:
    Supporting Member N00b Machinist's Avatar
    May 2016
    I assume the second photo, with the teeth flush with the top, is the not in use position. What holds the stop proud when you’re setting up the work piece?
    Jul 2014
    France, Brittany !
    Quote Originally Posted by N00b Machinist View Post
    Yes, exactly. It's a tight fit in its mortise, you need a few strokes of mallet from below the benchtop to rise it to the level you need.
    Cheers !
    Christophe
  6. The Following User Says Thank You to Christophe Mineau For This Useful Post:
    N00b Machinist (12-14-2020)
