Thread: Surface Grinder restoration: Making & Testing a DIY Table in my Workshop
    Supporting Member AB-SHOP's Avatar
    Aug 2022
    Italy
    AB-SHOP's Tools
    Hello everyone,
    I decided to build the magnetic spindle holder table for my tangential grinding, the hardest part? Making the 4 columns of the same length, I decided to leave 0.03 mm more and then correct each column; the final result is not bad even if I hoped to obtain greater precision.
    The error I obtained I will try to eliminate it by rectifying the magnetic plane in the next video.
    I determined the minimum distance from the grinding wheel, I then measured the 45° slot and used the same cutter to machine the lower plate.
    I then built a jig with the 3D printer so as not to remove the table from the milling machine and therefore lose the zeroing.
    I then built 2 columns to be able to work the rectangular holes where to insert the stop blocks
    The 4 columns were built with a knurled part to be able to forcefully lock them into the aluminum.
    Finally I built 2 stop blocks: since I couldn't tighten the M8 screws directly on the aluminum, I built 2 steel cylinders to release the pressure from the cylinder to the aluminum
    Hope you like the video too!
    See you soon,
    Alberto
    Attached Thumbnails Attached Thumbnails Surface Grinder restoration: Making & Testing a DIY Table in my Workshop-foto_1.jpg   Surface Grinder restoration: Making & Testing a DIY Table in my Workshop-foto_4.jpg   Surface Grinder restoration: Making & Testing a DIY Table in my Workshop-foto_5.jpg   Surface Grinder restoration: Making & Testing a DIY Table in my Workshop-foto_6.jpg   Surface Grinder restoration: Making & Testing a DIY Table in my Workshop-foto_7.jpg
    Surface Grinder restoration: Making & Testing a DIY Table in my Workshop-foto_8.jpg
  2. The Following 4 Users Say Thank You to AB-SHOP For This Useful Post:
    emu roo (Oct 1, 2024), Jon (Oct 2, 2024), mwmkravchenko (Oct 1, 2024), PJs (Oct 7, 2024)
    Thanks AB-SHOP! We've added your Spindle Holder Table to our Machining category,
    as well as to your builder page: AB-SHOP's Homemade Tools. Your receipt:
