Coupon code for 20% off membership: SPRING20
Results 1 to 7 of 7
Thread: Swaging HDPE water pipe using heat - GIF
    Altair's Avatar
    Save 20% on Membership
    nova_robotics (Feb 2, 2023), Ralphxyz (Feb 4, 2023)
    12L14's Avatar
    Aug 2017
    It doesn't look like HDPE - I bet it is just PVC.
    hemmjo's Tools
    Quote Originally Posted by 12L14 View Post
    I am curious how you can say it does not "look" like HDPE? You can get HDPE pipe at least 5' (1.54m) in diameter. I have done that very same same process with both HDPE and PVC, although not that large. HDPE is much wider band of temperature for forming than PVC. HDPE will stretch much further with less force and no damage to the actual structure of the material than with PVC.
    HDPE is typically joined by the fusion butt welding process, but slip fit bell end connections are also used for some applications.
    HDPE is much more chemical resistant than PVC and is used to many industrial applications.
  5. The Following User Says Thank You to hemmjo For This Useful Post:
    Frank S (Feb 3, 2023)
    Dec 2016
    Ralphxyz's Tools
    How would you glue HDPE as it is chemical resistant?
    Ralph
    Aug 2012
    Australia
    desbromilow's Tools
    I want to see how they get it off the swage!!!!!
    hemmjo's Tools
    Ralph
    Depending on the application, it may not need to be glued. Again, depending on the application there are now HDPE adhesives.
    Some epoxies work as well as some types of "super glue"
  9. #7
    12L14's Avatar
    Aug 2017
    Quote Originally Posted by hemmjo
    Way too much outgassing, edge isn't melting as fast as it should, if video was of better quality, colour of flame could tell us more.
    As for PP and PE, you are not glueing them directly - but altered(so no longer PP or PE) surface.
