a try...
https://youtu.be/fR8WBkhJ6po
My previous works
Thanks RCTURKA! We've added your T-Track Router Bit to our Routing category,
as well as to your builder page: RCTURKA's Homemade Tools. Your receipt:
<div id="blocks"> <div class="block b1 pngfix"> <div class="bimg"> <div> <a href="https://www.homemadetools.net/homemade-t-track-router-bit-2"> <img src="/uploads/260428/homemade-t-track-router-bit-2.jpeg"/> </a> </div> </div> <div class="head pngfix"></div> <div class="left pngfix"></div> <div class="right pngfix"></div> <div class="blockover b1 pngfix"> <div class="title"> <a href="https://www.homemadetools.net/homemade-t-track-router-bit-2">T-Track Router Bit</a> <span> by <a href="https://www.homemadetools.net/builder/RCTURKA">RCTURKA</a></span> </div> <div class="tags">tags: <a href='https://www.homemadetools.net/tag/router'>router</a> </div> </div> </div> </div>
Just a thought... The bit seemed to struggle even at low travel speeds. Consider cutting the slot with a conventional bit or table saw before finishing with this bit. That was it's only working the material on the sides of the slot. It would let you blaze through the slot with this bit, and would wear this bit less.
Neil
