https://www.youtube.com/watch?v=XpYx3PNLNOE
I made this jig for measuring table saw blade angles accurately, but it proved to be best at setting it to 90°. I love how accurate it is and how easy to use.
Nice jig. Setting the correct and exact angle on the table saw takes some practice. By the way my favorite table saw blade is the Freud LU87R009 9-Inch 22 Tooth ATB Thin Kerf Ripping Saw Blade with PermaShield Coating. I cut a lot of hardwoods (mahogany, oak and a very hard birch) and this blade does a superior job in ripping with no burn marks and still produces a glass-like cross cut finish. The 9" model has a very thin kerf and is pretensioned for truer cuts under heavy loads. I use it for all types of cuts. Thanks for the video.
Thanks tony_912! We've added your Table Saw Blade Angle Setting Tool to our Angle Guides and Try Squares category, as well as to your builder page: tony_912's Homemade Tools. Your receipt:
<div id="blocks"> <div class="block b1 pngfix"> <div class="bimg"> <div> <a href="http://www.homemadetools.net/table-saw-blade-angle-setting-tool"><img src="http://www.homemadetools.net/uploads/143075/table-saw-blade-angle-setting-tool.jpeg" /></a></div> </div> <div class="head pngfix"></div> <div class="left pngfix"></div> <div class="right pngfix"></div> <div class="blockover b1 pngfix"> <div class="title"> <a href="http://www.homemadetools.net/table-saw-blade-angle-setting-tool">Table Saw Blade Angle Setting Tool</a> <span> by <a href="/builder/tony_912">tony_912</a></span> </div> <div class="tags">tags: <a href="http://www.homemadetools.net/tag/table-saw">table saw</a>, <a href="http://www.homemadetools.net/tag/angle">angle</a>, <a href="http://www.homemadetools.net/tag/dial-indicator">dial indicator</a></div> </div> </div> </div>
just a post to stay an active lurker
Welcome to HomemadeTools.net bstromb. :welcome: Feel free to lurk away :)
This is very similar to the technique that machinists use to test the squareness of cylinder squares and machinists' squares.
A steel base with a protruding foot (analogous to the screws) has a vertical beam that carries a DTI (Dial Test Indicator). On a granite surface plate the foot is pressed against the cylinder square and the DTI reading noted. Then this action is repeated on other points around the square circumference. Adjustments are made until all readings coincide. Note that the beam need not be precisely orthogonal to the base; it only has to be rigid so the point of the DTI remains the same distance from the foot.
Hi bstromb,
Welcome! :welcome:
What sort of homemade tools do you prefer to lurk on? :lol:
Ken
