Page 2 of 2 FirstFirst 1 2
Results 11 to 15 of 15
Thread: Tailstock alignment buttons
    Oct 2012
    Sometimes there are thing that come up that just stir me. WE ARE NONE NASA ENGINEERS or will we be. A few thousands will not hurt anything.
    When we look at blueprints they tell us how many of those "0" we can delete. Not everything has to be within 0.0002 - 0.0000
    Nelson
  2. The Following User Says Thank You to ncollar For This Useful Post:
    olderdan (Sep 7, 2018)
  3. #12
    Jul 2018
    Flora, MS
    Floradawg's Tools
    Thanks Mklots,
    I will make a set. When turning between centers I have always turned a 60 degree angle on a piece of round stock chucked up. It is the easiest way and like you said probably the most accurate. It helps to have a step on it to keep it from moving into the chuck.
  4. #13
    Mar 2014
    Beaumont, TX
    Paul Alciatore's Tools
    I know this is an old post, but it's a great idea. I am glad I ran across it. Thanks!
    Paul A.
  5. #14
    Quote Originally Posted by Paul Alciatore View Post
    Thanks, Paul. It's a great deal quicker than turning a test piece between centers, measuring the resulting taper, and then trying to calculate the required tailstock setover, set up a DI to measure the required movement and then repeat all this until no taper is turned.
    Short tapers are best turned using the compound. For longer tapers, an offsetable (is that a word?) tailstock center is worth building if one has more than a few tapers to make. Once I have the tailstock aligned, I hate to offset it so the offsetable style appeals to me.
    For the benefit of folks who may not be familiar with them, use Google Images with a search term of
    offsetable tailstock center
    to see pictures of what I'm on about. [Google seems to understand 'offsetable' so I guess it is a word.]
    and, of course, Amazon sells them...
    https://www.amazon.com/IMPROVED-TURN...%2C117&sr=8-35
    https://www.amazon.com/Precision-Sha...%2C117&sr=8-36
    Home Shop Freeware
  6. The Following User Says Thank You to mklotz For This Useful Post:
    Floradawg (Apr 29, 2022)
  7. #15
    Jul 2018
    Flora, MS
    Floradawg's Tools
    Thanks for the links. I didn't know about these. Might buy the cheaper one.
