Results 1 to 4 of 4
Thread: Tailstock Threading Die Holder for the Mini-Lathe
    SculptyWorks's Avatar
    Sep 2019
    Virginia
    Wink Tailstock Threading Die Holder for the Mini-Lathe
    Hey folks! My first post here! Yay!
    I'm going to start with my first actual tool video from YouTube, a tailstock threading die holder for my Harbor Freight 7x12 mini lathe.
    This was a lot of fun to make and has seen so much use already, I don't know how I lived without one for so long!
  2. The Following 5 Users Say Thank You to SculptyWorks For This Useful Post:
    bruce.desertrat (09-17-2019), DIYer (09-15-2019), Jon (09-15-2019), metric_taper (09-16-2019), sossol (09-22-2019)
    Thanks SculptyWorks! We've added your Threading Die Holder to our Tapping and Threading category,
    as well as to your builder page: SculptyWorks's Homemade Tools. Your receipt:
    SculptyWorks (09-15-2019)
    Marion, Iowa
    metric_taper's Tools
    Nice knurling job, looks like boring out solid stock is a bit of a job on the small lathe. Thanks for posting.
    I made one of these the other day, not for the lathe, but I was working on my 57 truck, where someone put in real long bolts to hold the seat in the cab. They stuck down about 30mm from the bottom. The frame was in the way of spinning on the die, hence a long extension to drive the die was needed. The bolts were very rusty (winter salt spray), and after twisting one off, I made this tool to run the die up the rusted threads, so the other 7 bolts would not twist off. I need to make a set of these for all the different die diameters, as this is not the first time I've run into this issue of driving a die where there is no clearance for the die stock handles. I was lucky to have a piece of tubing that required very little material removal.
  6. The Following User Says Thank You to metric_taper For This Useful Post:
    SculptyWorks (09-16-2019)
    Sep 2019
    Virginia
    Thanks!
    Yes, it's a bit of a job to bore that much material on that little lathe, but it could have been a lot easier/faster if I had a proper boring bar. The one I used there I made pretty much on the spot out of a pin punch.
    I made an adapter for it because I also have a bunch of little hexagonal dies. An adapter was simpler to make (and takes less space) than making a whole new tool.
    Post your reply!
    Join 41,949 of us and get our 173 Must Read Homemade Tools eBook free.
