Coupon code for 20% off membership: SPRING20
Thread: Tap Holder - my take
    Aug 2019
    Oregon, USA
    BuffaloJohn's Tools
    I have seen many versions of tap holders, but I decided to try to make one using the Irwin 3/8" socket tap holders:
    There are two different holders, both with 3/8" square sockets. I took a 3/8" extension and cut off the socket end. I made a holder that is held by the drill chuck that also has a hole that the cut off extension fits into. Onto the extension, there is a hollow cylinder that has a hole drilled through it and through that hole, I put a scrap rod to be the handle. As you can see, the handle is about 1/3 the diameter of the extension.
    Here are some more images:
    All the parts
    There is a little wobble in the 3/8" drive socket, but it tracks the hole nicely once everything is lined up. I have tapped both on the mill and the lathe and both with small and larger taps. One thing I like is that there is quite a bit of depth in the extension holder, so I can set that holder into the chuck, add the extension part, and then add the tap with only a short engagement to the square drive - works well for me.
    Save 20% on Membership
  2. The Following 3 Users Say Thank You to BuffaloJohn For This Useful Post:
    bruce.desertrat (Jan 26, 2023), emu roo (Jan 29, 2023), Jon (Jan 26, 2023)
    Thanks BuffaloJohn! We've added your Tap Holder to our Tapping and Threading category,
    as well as to your builder page: BuffaloJohn's Homemade Tools. Your receipt:
    BuffaloJohn (Jan 29, 2023)
