Thread: Tapping fixture and auto reversing tapping head
    Berkshire UK
    thehomeengineer's Tools
    Hi All
    This is an adjustable tapping fixture, which I made to use in conjunction with an auto reversing tapping head. The idea is to set the work-piece so it is supported and held in the fixture but is easily slid within the fixture. The fixture is then, positioned under the drill spindle and bolted to the table and each hole in that plain, can be tapped. (The video should clarify this).
    The clutch on the tapping head can be set to avoid breakage. To reverse the direction of the tapping head you simply lift the quill upwards, which reverses the direction of the cutting tool without having to switch the machine off or change the motor direction. The hexagon bar acts as a stop to prevent the main body of the tapping head from rotating.
    Tapping fixture and auto reversing tapping head-img_1760.jpg setting the work-piece in fixture
    The Home Engineer
  2. The Following 13 Users Say Thank You to thehomeengineer For This Useful Post:
    Bobinwa (Jun 17, 2018), emu roo (Mar 26, 2025), HobieDave (Mar 27, 2020), jjr2001 (Mar 1, 2019), johnsmachines (Oct 3, 2018), Jon (May 29, 2018), LMMasterMariner (Jun 2, 2018), PJs (May 31, 2018), rlm98253 (May 29, 2018), rossbotics (May 29, 2018), Scotsman Hosie (Apr 12, 2019), Seedtick (May 29, 2018), Toolmaker51 (May 30, 2018)
    Thanks thehomeengineer! We've added your Tapping Fixture to our Tapping and Threading category,
    jjr2001's Tools
    Thanks homeengineer. That is a nice fixture for the tapping of small parts.
    I was trying to come up with something along these lines that would work
    for various size pieces and you have a great solution. Looks like it would
    also work for drilling and countersinking or chamfering holes.
    Cheers, JR
    Download plans for drilling and drill presses.
    Back to the shop.
  5. The Following User Says Thank You to jjr2001 For This Useful Post:
