Results 1 to 5 of 5
Thread: Thermoplastic welding tool - GIF
    Thermoplastic welding tool.
    Plastic bottle blow molding process - video
    Rotational plastic molding a large tank - GIF
    Plastic cup manufacturing GIF
  2. The Following 8 Users Say Thank You to Jon For This Useful Post:
    Andyt (Dec 19, 2019), baja (Dec 19, 2019), emu roo (Oct 2, 2024), MIGuy (Dec 18, 2019), Ralphxyz (Oct 8, 2024), Scotsman Hosie (Dec 20, 2019), Scotty12 (Dec 18, 2019), Tule (Dec 22, 2019)
    Jun 2012
    Harvey Melvin Richards's Tools
    That is a clever device to trim the weld. I have always used a wood chisel sharpened to a very narrow angle, and I flush the weld in a single pass.
    Dec 2016
    Ralphxyz's Tools
    Is the heat source a soldering iron?
    Jun 2012
    It is like a solder iron, except that it is hollow so that compressed air at around 3 to 4 psi can be blown through to heat the rod and the main material. On very important welds you would use nitrogen gas instead of compressed air.
  6. The Following User Says Thank You to Harvey Melvin Richards For This Useful Post:
    Dec 2017
    NeiljohnUK's Tools
    Hot air tool, I have one sat under my work desk at the moment as I have some plastic welding to do for a chemical wet deck modification project. Good prep is essential, mitre the edges, final scrape to remove oxidation just before welding etc. The clean up cutting off the bead isn't something we do if ultimate strength is important though.
  8. The Following User Says Thank You to NeiljohnUK For This Useful Post:
    Jon (Dec 19, 2019)
