Results 1 to 10 of 13
Thread: Tire lift and aligner
    Supporting Member ruxu's Avatar
    May 2017
    Southern Finland
    ruxu's Tools
    As both my daily driving car and my forest utility vehicle have quite heavy tires - 255/55-18 and 235/60R15 off-road - the twice a year changing from winter spikes tires to summer tires and vice versa requires lifting and aligning the rims onto the bolt pattern.
    As I had a 2ton floor jack with a small oil leak I decided to make a tire lift and aligner of it to make the tire changing easier. Here are some pictures of the modification. The whole mod was made of scrap metal parts and some bearings I had laying around.
Name:	Väliprojekti - Rengasnostin 1.jpg
ID:	17773 Click image for larger version.
Name:	Väliprojekti - Rengasnostin 2.jpg
ID:	17774 Click image for larger version.
Name:	Väliprojekti - Rengasnostin 3.jpg
ID:	17775 Click image for larger version.
Name:	Väliprojekti - Rengasnostin 4B.jpg
    The third picture of the new/modified parts is missing the bottom support flat bar that can be seen on the second picture.
Name:	Väliprojekti - Rengasnostin 5.jpg
    As I changed the tires on my wife's Ford Focus yesterday I tested the lift even though the tires aren't that heavy on a such small car. It worked as planned and the bolt alignment was very easy to do as you could lift the tire to correct height and rotate the tire.
    You could even use a new floor jack for this mod as they cost only 25 Euro.
  2. The Following 22 Users Say Thank You to ruxu For This Useful Post:
    baja (Oct 12, 2024), bobs409 (May 5, 2017), DIYer (May 4, 2017), Dollar Bill (Jul 15, 2023), EnginePaul (Apr 17, 2018), j.bickley (May 4, 2017), jeanalvitre (Aug 25, 2018), Jon (May 4, 2017), KustomsbyKent (May 4, 2017), lawlie (Dec 28, 2020), metric_taper (Jul 14, 2023), mr mikey (Oct 12, 2024), n9dug (Oct 3, 2020), Paul Jones (May 4, 2017), Priemsy (Apr 17, 2018), Ralphxyz (Oct 12, 2024), Rangi (Aug 7, 2018), Seedtick (May 4, 2017), that_other_guy (Oct 20, 2019), thehomeengineer (May 3, 2018), Toolmaker51 (May 6, 2017), Tule (Apr 18, 2018)
