I've tested my CNC plasma cutter with a simple build of a garden torch.
https://youtu.be/zR_WssiiuQg
How long did the T-P roll burn?
I recall the toilet paper bypass oil filter my father had on his '64 Olds...
I remember an employee of our Nor Cal timber yard had a 56 F100 with a TP aux filter.
We used to pull the core out of a roll of Tp then force the roll in a 1lb coffee can pour in a pint of common isopropyl 70% then light it to keep our deer stands warm. you got used to the smell after a while and since the cutouts didn't have window glass the open air was plenty of ventilation they would last for several hours if you placed a tin cover over it which blocked off some of the opening of the top. hardly any flame almost like sterno
