Results 1 to 10 of 412
    -I'm just curious, Frank - what "enzyme"/ chemical are you using to stabilize the floor?
    A name, link to a supplier/ MSDS would be much appreciated.
    ATB
    Johan
    I'm not at all sure if I would class it as a chemical per-SAY The enzyme appears to be a derivative of an organic concentrate or an extract my best guess would be soured or fermented fruit probably grapes combined with a surfactant.
    the recommended amount for my floor was 1 1/2 gallon to 300 gallons of water to do the entire floor.
    I had the opinion that the soil should have had at least a 20% moisture content to aid in the natural wicking action but was told no you wont have to wet the soil first as long as there was at least a 20% clay in the soil it should be fine.
    What I couldn't get them to understand was my fill had a higher clay content and 0% topsoil in the mix as it had only clay and what is known as silt or a red clay sand dust with a small amount of caliche and the moisture content was lower than kiln dried bricks It has had 2 years of traffic over it while being added to and packed down.
    the poor guy who tilled it up for us spent from 9AM until 4 PM trying to grind it up the best he could. it wasn't until the last hour of his tilling until it stopped sounding like he was trying to drive as rock crusher over it. For the first 4 hours as he tried to till it the huge clods I had left when I broke up the floor with the bucket of the back hoe would get caught in his tiller and stall his tractor once in a while.
    After he finished grinding he leveled it out pretty good then we sprayed 300 gallons of the mix then he tilled that in a few inches releveled it then drove his tractor back and forth until every inch had been ran over then I ran a 5000lb steel drum vibratory roller over it until after 9PM at least a good 4 hours.
    The next morning we added a second application rolled it again for another 4 hours. So what ever it is will be what it is. We should know in a week but the process may be delayed due to expected cooler temperatures
    https://www.substrata.us/perma-zyme
  2. The Following 2 Users Say Thank You to Frank S For This Useful Post:
    baja (Dec 31, 2020), DIYSwede (Dec 31, 2020)
