Results 1 to 8 of 8
Thread: Tool unknown
    mariusmarius's Avatar
    Apr 2015
    Romania, Buzău County
    Tool unknown
    Hi everyone!
    Someone from a local trade bussiness, bought a heavy piece with a lot of threaded holes M10 standard. One face has 12 degree.
    What is this and how I can use it in my garage shop activity?
    Thank you!
    [ATTACH=CONFIG]21499
    [/ATTACH][ATTACHTool unknown-img_1724_hmt.jpgTool unknown-img_1726_hmt.jpg=CONFIG]21500[/ATTACH]
    Attached Thumbnails Attached Thumbnails Tool unknown-img_1723_hmt.jpg   Tool unknown-img_1728_hmt.jpg
  2. The Following User Says Thank You to mariusmarius For This Useful Post:
    Seedtick (Jan 14, 2018)
    Almost certainly a piece of tooling for a particular job.
    I agree it's tooling, likely presented upper surface of work at the angle to drill, mill, or grind.
    Hard to say if whether oriented as shown or an angle to that; such as angle plate or rotary table etc. It might been used with location devices to set parts dependably on a certain location as well.
    As a bare plate it's 'tooling', used in conjunction with a machine for results.
    With clamping, it's a 'fixture', actually holds part securely enough to perform work.
    With items to guide tools, such as drill bushings, then it is a 'jig'. Jigs are designed and built with a certain type operation in mind, and usually a particular type of machine.
    None of those restrict how you can utilize it, infinitely. While 'drill, mill, grind' are obvious, it could be attached to a lathe [albeit large] face-plate or fixture on centers, very common for work on castings, notoriously challenging to clamp properly.
    Guaranteed worth more than it's weight in scrap. Whatever work done in previous shop might be a clue; but they could have acquired and saved it, as we say, just in case...If I tripped across one, I'd take it too.
    So, real answer is dependent on someone's need + creativity!
  5. The Following 2 Users Say Thank You to Toolmaker51 For This Useful Post:
    aphilipmarcou (Jan 14, 2018), PJs (Jan 16, 2018)
    Supporting Member aphilipmarcou's Avatar
    Dec 2016
    new zealand
    aphilipmarcou's Tools
    "If I tripped across one " I would try quite hard to trip on that .....(
    Marnat3's Avatar
    St Paul Minnesota
    Almost looks like a jig or mount for cylinder heads to bring them to level for machining.
    Dec 2016
    It is a fixture for machining 12 degree jigs.
  9. The Following User Says Thank You to owen moore For This Useful Post:
    tonyfoale (Jan 15, 2018)
  10. #7
    Dec 2015
    Reading, Berks, UK
    Philip Davies's Tools
    I would use it to bend steel, by inserting rods into the holes to achieve the desired radius.
  11. The Following User Says Thank You to Philip Davies For This Useful Post:
    Toolmaker51 (Jan 17, 2018)
  12. #8
    Jan 2018
    May a jig for holding or welding
