Results 1 to 5 of 5
Thread: THIS TOOL WILL HELP metal workers and if you WORK WITH WIRE crimper BEVEL MAKER
    Jan 2022
    diy creative crafts's Tools
  2. The Following 13 Users Say Thank You to diy creative crafts For This Useful Post:
    baja (Feb 15, 2022), bear14 (Feb 21, 2022), bob47907 (Feb 15, 2022), dietmar g (Feb 25, 2022), DIYer (Feb 15, 2022), Jon (Feb 17, 2022), NortonDommi (Feb 16, 2022), nova_robotics (Feb 18, 2022), RetiredFAE (Feb 15, 2022), rlm98253 (Feb 14, 2022), Sleykin (Oct 16, 2023), Toolmaker51 (Feb 14, 2022), wolfpaak (Feb 21, 2022)
    Thanks diy creative crafts! We've added your Cable Terminal Crimper to our Electrical category,
    as well as to your builder page: diy creative crafts's Homemade Tools. Your receipt:
    New plans added on 02/05/2025: Click here for 2,738 plans for homemade tools.
    Mar 2014
    Beaumont, TX
    Paul Alciatore's Tools
    Having worked in electronics for over 45 years and having crimped literally tens of thousands, probably hundreds of thousands of connectors, I VERY STRONGLY recommend AGAINST any home-made or shop-made tooling for any of them.
    No matter how well you say you can do the job with such a tool, there are bound to be some that are under-closed and others that are over-closed. This leads to corrosion in the one case and weakening of the wire in the other. Either of these conditions produces an unreliable joint which is a ticking time bomb in whatever item it is part of.
    In addition to all the installations of crimps I mentioned above, I have had to replace thousands of failing ones due to bad crimps. YES, THEY DO FAIL. FREQUENTLY!
    Paul A.
  5. The Following User Says Thank You to Paul Alciatore For This Useful Post:
    Apr 2012
    NorCal
    Saltfever's Tools
    Hi Paul and sorry I'm so late in coming to this party. I appreciate your warning and I'm in sync with your premise of making a quality crimp. I'm sure any professional tool has been tested and test results confirm application quality. However, there are so many variables in cable design I'm wondering how, in your experience, you compensate for all the difference you encounter in the field. As a non-"electrical" person I'm bewildered by the all possibilities to make a wrong application.
    Supporting Member Sleykin's Avatar
    Oct 2017
    Medford, Oregon USA
    Sleykin's Tools
    I was an electronics tech for 36+ years. I installed and maintained NAV/RAD/COM equipment the whole time. I absolutely hated crimps. I was required to use crimps on many of the com stuff. Frequently a problem. I did use swaging tools on large solid connectors. For large, stranded wire, I us solder and maybe a crimp to start. For automotive type wiring I do use crimps with a properly adjusted ratcheting crimper. Marine grade heat shrink tube goes over the connections if they are outside things.
    Be careful with RTV around electrical connections. Most RTV has acetic acid in it that outgasses as it dries. This will cause corrosion inside the connections. There is a special RTV made for electronics, and it will say safe for electronics.
    Sorry I am so late to the party LOL
  8. The Following User Says Thank You to Sleykin For This Useful Post:
    Saltfever (Jan 26, 2025)
