Page 2 of 2 FirstFirst 1 2
Results 11 to 14 of 14
Thread: Trailer motor mover
    Berkshire UK
    thehomeengineer's Tools
    Your hitch-ball-standpipe is a simple lever (or moment arm). Its pivot point is where it is attached. The trailer weight (load, brakes, incline, etc.) is a force. When the ball moves, the trailer force reacts against it and wants to rotate it around its attach point. The wheels on the ground resist this movement until the force is great enough to start lifting the other end. The ball is not located in the center of the chassis so the tipping force will vary depending on the direction. I believe your "lock" restricts rotation of the ball, greatly minimizing the tipping effect. This is why I am interested in your locking mechanism.
    I have posted a link to the hitch lock located at Trailer motor mover ball locking mechanism
    Hopefully will help
    Download plans for trailers and towing tools.
  2. The Following User Says Thank You to thehomeengineer For This Useful Post:
    Saltfever (Aug 4, 2024)
  3. #12
    The setup looks solid, especially with those heavy-duty wheels and the locking mechanism. For the winch switch issue, replacing the plug with a higher quality one sounds like a good move.
  4. #13
    Berkshire UK
    Quote Originally Posted by LeeHael View Post
    The plug and socket has now been upgraded to a Plessey which has solved the intermittent fault. On close inspection, the plug was very loose in the socket which I believe was causing the fault rather than loose or damaged wire.
  5. #14
    Congratulations thehomeengineer - your Trailer Motor Mover is the Homemade Tool of the Month for August 2024!
    This is not only an excellent tool build, but the total project also encompassed multiple other homemade tools, including: Trailer Ball Locking Mechanism, Winch Plug and Socket Modification, Underslug Motor Plate, Winch Spool Modification, and Trailer Mover Hubs.
    Some more good builds from August:
    Burnishing Tool by Mook
    Cable Stripper by thehomeengineer
    Windshield Seal Installation Tool by Frank S
    Cutoff Tool by winkys workshop
    Ornamental Turning Device by The Hobby Machinist NZ
    Allen Wrench Handle by rgsparber
    Knife by Mazay
    Forcing Screw by Alans Home Workshop
    Bar Stock Bender by orioncons36
    Hoe Bucket Cleaning Method by hemmjo
    Extra Long Probe by mklotz
    Creeper Fence Jig by Make Things
    Electric Cargo Cart by fawabros
    Auto Retract Threader by celsoari
    Cordless Battery Pack Repair by ercaneverything
    Vise by orioncons36
    Engineer's Parallels by Improvised DIY
    Milling Table Tool Setter by Alans Home Workshop
    Engine Trolley Modification by th62
    Lathe Polishing Attachment by mariost
    Lathe Chuck Stop by mariost
    Welding Torch Holder by orioncons36
    Debris Fork by Chips O'Tool
    Welding Cart by winkys workshop
    Sharpening Attachment by PaulsGarageProjects
    Workbench by Cazual Haze
    thehomeengineer - You'll be receiving a $250 cash prize, in your choice of Amazon, PayPal, or bitcoin. Please PM me your current email address and prize choice and I'll get it sent over right away.
    And, you'll now notice the four-column award in the awards showcase in your postbit, visible beneath your username:
    Nice work
