Thread: Trolley for homemade gantry beam
    katy's Avatar
    Jul 2019
    Red Deer Alberta
    katy's Tools
    Here’s a small trolley I built a few years ago for my small homemade gantry. The gantry uses a 2” square tube (1/4” wall) for the cross beam. The side plates are cut from ” plate, the rollers are 6205- 2RS bearings, the “axles” are made from 1” stock 2-1/8” long w/both ends turned down to 25mm for the bearings with 9/16” between, then drilled and tapped both ends for bolts. Holes drilled in the plates for a load support thimble. A ” nut was welded to one side for a T bolt to lock the trolley in position. Drilled the end of the thimble bolt for a hairpin cotter pin, for safety. The plates are 8” wide and 7” top to bottom, but could be any size, I just used what I had on hand.
    The gantry was a little narrow for some applications so it was extended with 6"X6"X12" I beam pieces. Load tested to 700 lbs.
    Trolley for homemade gantry beam-trolley-1.jpgTrolley for homemade gantry beam-trolley-2.jpgTrolley for homemade gantry beam-trolley-3.jpgTrolley for homemade gantry beam-trolley-4.jpgTrolley for homemade gantry beam-gantry-detail-2-.jpg
  2. The Following User Says Thank You to katy For This Useful Post:
    Jon (Apr 13, 2021)
    Thanks katy! We've added your Gantry Trolley to our Winches category,
    as well as to your builder page: katy's Homemade Tools. Your receipt:
