Results 1 to 5 of 5
Thread: Tubing press/cut/punch machine - GIF
Hybrid View
    Tubing press/cut/punch machine.
    Wafios tube bending machine - GIF
    Steel tube squaring machine - GIF
    Making steel tubing - GIF
  2. The Following 10 Users Say Thank You to Jon For This Useful Post:
    baja (Jul 12, 2019), KustomsbyKent (Jul 12, 2019), Miloslav (Jul 13, 2019), Quinton 357 (Jul 13, 2019), Rangi (Jul 12, 2019), rdarrylb (Nov 16, 2024), rlm98253 (Jul 11, 2019), Scotsman Hosie (Jul 13, 2019), Seedtick (Jul 11, 2019), Toolmaker51 (Jul 14, 2019)
    Now a quick dress up on a belt grinder and the part is ready for coating and assembly
    Dec 2014
    South Dakota
    KustomsbyKent's Tools
    Nice piece of stamping tooling... I wonder what the end use is to justify the cost of the tooling? With that tooling, you should be able to do hundreds of these per hour, so it must be something with some volume needs.
  5. The Following 2 Users Say Thank You to KustomsbyKent For This Useful Post:
    Quinton 357 (Jul 13, 2019), Toolmaker51 (Jul 14, 2019)
    The tooling is a pretty standard design for that, but in a mechanical conventional punch press. An easy 150 hits per minute. Good production rate volume
    They appear to use something like an H-frame assembly press, or maybe an ironworker, definitely hydraulic evident by markedly slower rate. Low production rate, but safer for unskilled operators.
    Supporting Member carl blum's Avatar
    Nov 2021
    Charleston, South Carolina
    carl blum's Tools
    Hi Gang:
    It is a 4 post ball bearing die set, way more precession than required. The punch is guided by the stripper, and the cut-off punch has a heal for the side thrust.
    Carl.
