Tubing press/cut/punch machine.
Wafios tube bending machine - GIF
Steel tube squaring machine - GIF
Making steel tubing - GIF
New plans added on 12/06/2024: Click here for 2,617 plans for homemade tools.
baja (Jul 12, 2019), KustomsbyKent (Jul 12, 2019), Miloslav (Jul 13, 2019), Quinton 357 (Jul 14, 2019), Rangi (Jul 12, 2019), rdarrylb (Nov 16, 2024), rlm98253 (Jul 11, 2019), Scotsman Hosie (Jul 14, 2019), Seedtick (Jul 11, 2019), Toolmaker51 (Jul 14, 2019)
Nice piece of stamping tooling... I wonder what the end use is to justify the cost of the tooling? With that tooling, you should be able to do hundreds of these per hour, so it must be something with some volume needs.
Quinton 357 (Jul 14, 2019), Toolmaker51 (Jul 14, 2019)
The tooling is a pretty standard design for that, but in a mechanical conventional punch press. An easy 150 hits per minute. Good production rate volume
They appear to use something like an H-frame assembly press, or maybe an ironworker, definitely hydraulic evident by markedly slower rate. Low production rate, but safer for unskilled operators.
