Results 1 to 5 of 5
Thread: Turning outside calipers inside
    My smallest inside calipers could not even be forced into a 7/8" ID tube and I needed to verify a 1" counter bore about an inch inside the opening
    So I modified an old pair of outside calipers to be inside.
    thehomeengineer (Jan 16, 2022)
    Thanks Frank S! We've added your Inside Calipers to our Calipers category,
    Berkshire UK
    thehomeengineer's Tools
    Odd leg Jenny modification
    Hi All
    Frank I hope you donít mind me high jacking your post. But one of the best modifications I made, was to a set of odd leg Jennyís. I use these all the time for marking out. Often there is a need to mark off from a shoulder, tipped sheet metal edge, flanged edge and casting etc. The main reason I opted for this modification was to aid marking out flanged edges from templates on copper boiler plateís.
    So I simply inverted the leg so it could run along the opposite side. Hopefully the photos below will make this clearer.
    Turning outside calipers inside-f3e4f737-7138-436c-973e-9b7e9bad2fe9.jpeg Turning outside calipers inside-936c4759-a18a-4822-a6cb-84089359be17.jpeg
    Many thanks again Frank for the original post
    Link to original post Turning outside calipers inside
    The Home Engineer
  5. The Following User Says Thank You to thehomeengineer For This Useful Post:
    Frank S (Jan 16, 2022)
    Quote Originally Posted by thehomeengineer View Post
    Hi All
ID:	41558 Click image for larger version.
    The Home Engineer
    Yep, the use of these are just about forgotten in the world of CNC and digital measuring devices. It takes a delicate touch to use them properly
  7. The Following User Says Thank You to Frank S For This Useful Post:
    thehomeengineer (Jan 17, 2022)
    Thanks thehomeengineer! We've added your Marking Calipers to our Measuring and Marking category,
