Get 500+ homemade tool plans, tool build guides, ebooks, and much more.
Results 1 to 8 of 8
Thread: - Ultimate circle cutting guide-
    Jyväskylä Finland
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Tuomas's Tools
    Made a new tool.
    Its a circle cutting guide that can be used with non-ferrous metals too, also with wood.
    Material cost about 17$
    Made it as a prototype for a commercial manufacturing, but i tought i could share the idea with diy people too.
    Actual commercial product will be little different, but the idea is similar.
    10$ suction cup ( made for lifting windows etc )
    https://www.motonet.fi/fi/tuote/765143/Imukuppi-nostoon
    Three bearings and surplus steel.
  2. The Following 14 Users Say Thank You to Tuomas For This Useful Post:
    123pugsy (04-07-2019), bobs409 (04-08-2019), Corm (04-15-2019), Duke_of_URL (04-09-2019), Jon (04-08-2019), Ken Koch (05-15-2019), LMMasterMariner (04-09-2019), olderdan (04-06-2019), PowerMk (04-10-2019), saintrain (04-06-2019), Scotsman Hosie (05-14-2019), Tonyg (05-15-2019), tyson 690 (06-09-2020), wgfabrication (05-13-2020)
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thanks Tuomas! We've added your Circle Cutting Jig to our Metalworking category,
    Jyväskylä Finland
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Tuomas's Tools
    Pictures:
    I made it mountable to my 125mm angle grinder and plunge router, but it can be mounted to jig saw, plasma cutter... etc
    Works with every non-porous surface. Mdf, plywood, plastics, glass, metals, stone, tiles...
    Originally i designed smaller version from this, for the be used with dremel rotary tool.
    To cut circles / holes / arches, to tiles ( with tungsten carbide blade ) and for engraving circles / arches to glass.( with diamond wheel )
    Bigger version should cut tiles / stone too, with diamond cut off wheel.
    Jyväskylä Finland
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Tuomas's Tools
    Plans:
    Arms can be lock to set distance by tightening M5 screws on the sides.
    6mm rods works as an arms. These rods go trough the blocks made from 20 x 20mm bar.
    Holes where these rods goes trough the bar. Are located so, that holes hit to the 10mm holes of the swiveling axle. 10mm axle is grooved from this section, around the axle, from both ends.
    I made those grooves with dremel using tungsten carbide cutter.
    These 6mm axle leans to the grooves, this locks the swiveling head sideways, and keeps it centered with the bearings, that are located to the center of the suction cup.
    More info at the plans itself.
    Ask if you have questions.
    Thank you for checking this out.
  6. The Following 2 Users Say Thank You to Tuomas For This Useful Post:
    Scotsman Hosie (05-14-2019), wgfabrication (06-06-2020)
    Supporting Member Duke_of_URL's Avatar
    Aug 2018
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Fantastic idea and execution of design! Thanks!
  8. The Following User Says Thank You to Duke_of_URL For This Useful Post:
    Tuomas (04-09-2019)
    Jyväskylä Finland
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Tuomas's Tools
    Quote Originally Posted by Duke_of_URL View Post
    You're welcome.
    Thank you for checking it.
  10. #7
    May 2020
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    This is the best circle cutter for a grinder Ive seen. thank you.
  11. The Following User Says Thank You to wgfabrication For This Useful Post:
    Tuomas (06-06-2020)
  12. #8
    Jun 2020
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    This is absolutely awesome. I have been doing the old fashion way with a compass or if its bigger a piece of string tied to my sharpie and hold the other end. This will cut my time from 1 hour + to 5 - 10 minutes.
    Post your reply!
    eBooks for Supporters
  13. The Following User Says Thank You to tyson 690 For This Useful Post:
    Tuomas (06-10-2020)
