The Ultimate guide to Two Trees TTS-20 Pro Laser Cutter: Assembly and DIY Ideas!
https://youtu.be/-yyQNoFMYpg
Hello everyone,
In this video I tried the Two Trees TTS-20 Pro model, it is a 20W laser engraver that practically engraves on any material,
I have several tests also on stainless steel but it engraves on any steel: at the unboxing you will find the laser mounted at 95 %, it is also equipped with Air-assist so as not to dirty the cutting edges with dust coming from the cut itself,
I consider the build quality of this machine, compared to the cost, truly remarkable and thanks to the ultra-thin cut (0.08x0.08 mm) gives remarkable results, as you can see from the video.
Alberto.
