Another Unimat lash-up:
Attachment 23227
Attachment 23227
Hi threesixesinarow,
I am always interested in the work of others and your work is always intriguing! The pictures are invaluable and give me ideas I could use myself.
Did you cut the dovetail for the vertical attachment in an existing Unimat head stock? Or did you make an entire new head stock? Lastly, what is the machine it is mounted on?
Dick
I’m glad they’re useful.
It’s new but there’s enough material at the bottom of a regular headstock to mill one the same way. A more attractive option might be bolting the front dovetail to the existing bottom which would only make it 5mm higher and you wouldn’t lose the indexing wing or the mounting post.
The rear dovetail is separate and is what clamps the headstock to the slide.
Here is a clearer view of that little machine but with a different spindle. Travels are about 4 x 3 x 2”.
Attachment 23260Attachment 23261
A funny Unimat setup.
Instead of plates I just use a two position index with a train of mini lathe change gears to set the number of divisions, or approximate ones like 23 in the second picture.
Attachment 23480
Attachment 23482
Attachment 24343
Unimat cross drilling adapter, with spindle brake shown at http://www.homemadetools.net/forum/n...ni-lathe-67849
Thanks threesixesinarow! We've added your Dividing Setup to our Measuring and Marking category,
<div id="blocks"> <div class="block b1 pngfix"> <div class="bimg"> <div> <a href="http://www.homemadetools.net/homemade-dividing-setup"> <img src="/uploads/214087/homemade-dividing-setup.jpeg"/> </a> </div> </div> <div class="head pngfix"></div> <div class="left pngfix"></div> <div class="right pngfix"></div> <div class="blockover b1 pngfix"> <div class="title"> <a href="http://www.homemadetools.net/homemade-dividing-setup">Dividing Setup</a> <span> by <a href="http://www.homemadetools.net/builder/threesixesinarow_2">threesixesinarow</a></span> </div> <div class="tags">tags: <a href='http://www.homemadetools.net/tag/lathe'>lathe</a>, <a href='http://www.homemadetools.net/tag/divider'>divider</a>, <a href='http://www.homemadetools.net/tag/gears'>gears</a> </div> </div> </div> </div>
Thanks threesixesinarow! We've added your Unimat Headstock Adaptor to our Lathe Accessories category,
<div id="blocks"> <div class="block b1 pngfix"> <div class="bimg"> <div> <a href="http://www.homemadetools.net/homemade-unimat-headstock-adaptor"> <img src="/uploads/214092/homemade-unimat-headstock-adaptor.jpeg"/> </a> </div> </div> <div class="head pngfix"></div> <div class="left pngfix"></div> <div class="right pngfix"></div> <div class="blockover b1 pngfix"> <div class="title"> <a href="http://www.homemadetools.net/homemade-unimat-headstock-adaptor">Unimat Headstock Adaptor</a> <span> by <a href="http://www.homemadetools.net/builder/threesixesinarow_2">threesixesinarow</a></span> </div> <div class="tags">tags: <a href='http://www.homemadetools.net/tag/adaptor'>adaptor</a> </div> </div> </div> </div>
Here is the angle iron cross drilling attachment with the dovetail Unimat headstock, as well as the rotating mount for the smaller spindle shown in the second picture of the little mill.
Attachment 24347Attachment 24346
That also works as a base for the little vise.
Thanks, Dick,
I only just learned about the small metal slides you can buy now reading on a different forum-they look alright, or at least better for something like this than the plastic and aluminum ones I saw before.
The table on my homemade slide is a lot narrower than those, though, and the whole thing’s about an inch shorter and has some things I didn’t see available in other designs. It made a big mess but the cast iron bar cut nicely and I didn’t have to worry about voids like on the base of the vertical slide.
As for versatility, we’ll see! It’s harder for me using ordinary work holding tools at this scale, and so far it has only been really useful for a few tasks, like making cutters. Some kind of toggle clamp system and an x-axis lever feed will help a lot for the repetitive things I want to do with it-so far it has been easier setting up to do them on a lathe (with Unimat parts, too), like cross drilling and even slotting.
⁃ Clark
Attachment 24380Attachment 24381
Rotary broaching using a Unimat.
Attachment 24526Attachment 24527
Makes a driving nut to fit an old Dremel collet chuck screwed onto a stationary, emergency moto-tool, for a flex shaft.
Attachment 24581
Thanks threesixesinarow! We've added your Unimat Cross Drilling Attachment to our Lathe Accessories category,
<div id="blocks"> <div class="block b1 pngfix"> <div class="bimg"> <div> <a href="http://www.homemadetools.net/homemade-unimat-cross-drilling-attachment"> <img src="/uploads/215496/homemade-unimat-cross-drilling-attachment.jpeg"/> </a> </div> </div> <div class="head pngfix"></div> <div class="left pngfix"></div> <div class="right pngfix"></div> <div class="blockover b1 pngfix"> <div class="title"> <a href="http://www.homemadetools.net/homemade-unimat-cross-drilling-attachment">Unimat Cross Drilling Attachment</a> <span> by <a href="http://www.homemadetools.net/builder/threesixesinarow_2">threesixesinarow</a></span> </div> <div class="tags">tags: <a href='http://www.homemadetools.net/tag/lathe'>lathe</a>, <a href='http://www.homemadetools.net/tag/drilling'>drilling</a> </div> </div> </div> </div>
Thanks threesixesinarow! We've added your Rotary Broaching on a Lathe to our Machining category,
<div id="blocks"> <div class="block b1 pngfix"> <div class="bimg"> <div> <a href="http://www.homemadetools.net/homemade-rotary-broaching-on-a-lathe"> <img src="/uploads/215501/homemade-rotary-broaching-on-a-lathe.jpeg"/> </a> </div> </div> <div class="head pngfix"></div> <div class="left pngfix"></div> <div class="right pngfix"></div> <div class="blockover b1 pngfix"> <div class="title"> <a href="http://www.homemadetools.net/homemade-rotary-broaching-on-a-lathe">Rotary Broaching on a Lathe</a> <span> by <a href="http://www.homemadetools.net/builder/threesixesinarow_2">threesixesinarow</a></span> </div> <div class="tags">tags: <a href='http://www.homemadetools.net/tag/broach'>broach</a> </div> </div> </div> </div>
New Unimat spindles to use in different machines - one plain bearing for slower speed and bigger through-spindle capacity, the other, just completed, with ball bearings for higher speed.
Both take ER-16 collets.
Attachment 25066
Attachment 25067
Ball bearing quill parts
Attachment 25068
Felt reservoir and labyrinth dust covers
Attachment 25072
Plain bearing quill parts drawing
Attachment 25070
Plain quill with threading attachment
Attachment 25071
Single-nut movable change gear post for banjo
Thanks threesixesinarow! We've added your Unimat Spindles to our Lathe Accessories category,
<div id="blocks"> <div class="block b1 pngfix"> <div class="bimg"> <div> <a href="http://www.homemadetools.net/homemade-unimat-spindles"> <img src="/uploads/216922/homemade-unimat-spindles.jpeg"/> </a> </div> </div> <div class="head pngfix"></div> <div class="left pngfix"></div> <div class="right pngfix"></div> <div class="blockover b1 pngfix"> <div class="title"> <a href="http://www.homemadetools.net/homemade-unimat-spindles">Unimat Spindles</a> <span> by <a href="http://www.homemadetools.net/builder/threesixesinarow_2">threesixesinarow</a></span> </div> <div class="tags">tags: <a href='http://www.homemadetools.net/tag/lathe'>lathe</a>, <a href='http://www.homemadetools.net/tag/spindle'>spindle</a> </div> </div> </div> </div>
Both in use - they run a lot smoother than the original, partly just from separating the motors.
Attachment 25139
Ball bearing quill drawing
Attachment 25267
“What they did, and how they did it”
Attachment 25378
Same design ER-11 quill mounted as a tool post grinder
Unimat wheel guard and overarm
Attachment 25968Attachment 25969
Attachment 25970Attachment 25971
Thanks threesixesinarow! We've added your Lathe Wheel Guard to our Lathe Accessories category,
<div id="blocks"> <div class="block b1 pngfix"> <div class="bimg"> <div> <a href="http://www.homemadetools.net/homemade-lathe-wheel-guard"> <img src="/uploads/218473/homemade-lathe-wheel-guard.jpeg"/> </a> </div> </div> <div class="head pngfix"></div> <div class="left pngfix"></div> <div class="right pngfix"></div> <div class="blockover b1 pngfix"> <div class="title"> <a href="http://www.homemadetools.net/homemade-lathe-wheel-guard">Lathe Wheel Guard</a> <span> by <a href="http://www.homemadetools.net/builder/threesixesinarow_2">threesixesinarow</a></span> </div> <div class="tags">tags: <a href='http://www.homemadetools.net/tag/lathe'>lathe</a>, <a href='http://www.homemadetools.net/tag/safety'>safety</a> </div> </div> </div> </div>
Thanks threesixesinarow! We've added your Lathe Overarm to our Lathe Accessories category,
<div id="blocks"> <div class="block b1 pngfix"> <div class="bimg"> <div> <a href="http://www.homemadetools.net/homemade-lathe-overarm"> <img src="/uploads/218478/homemade-lathe-overarm.jpeg"/> </a> </div> </div> <div class="head pngfix"></div> <div class="left pngfix"></div> <div class="right pngfix"></div> <div class="blockover b1 pngfix"> <div class="title"> <a href="http://www.homemadetools.net/homemade-lathe-overarm">Lathe Overarm</a> <span> by <a href="http://www.homemadetools.net/builder/threesixesinarow_2">threesixesinarow</a></span> </div> <div class="tags">tags: <a href='http://www.homemadetools.net/tag/lathe'>lathe</a> </div> </div> </div> </div>
For more power than the little round belt
Attachment 26180
Thanks threesixesinarow! We've added your Lathe Countershaft to our Lathes category,
<div id="blocks"> <div class="block b1 pngfix"> <div class="bimg"> <div> <a href="http://www.homemadetools.net/homemade-lathe-countershaft"> <img src="/uploads/218625/homemade-lathe-countershaft.jpeg"/> </a> </div> </div> <div class="head pngfix"></div> <div class="left pngfix"></div> <div class="right pngfix"></div> <div class="blockover b1 pngfix"> <div class="title"> <a href="http://www.homemadetools.net/homemade-lathe-countershaft">Lathe Countershaft</a> <span> by <a href="http://www.homemadetools.net/builder/threesixesinarow_2">threesixesinarow</a></span> </div> <div class="tags">tags: <a href='http://www.homemadetools.net/tag/lathe'>lathe</a> </div> </div> </div> </div>
Attachment 26793 Attachment 26794
With ball oiler googly eyes for fun
Attachment 26795
Thanks threesixesinarow! We've added your Steady Rest to our Lathe Accessories category,
<div id="blocks"> <div class="block b1 pngfix"> <div class="bimg"> <div> <a href="http://www.homemadetools.net/homemade-steady-rest-55"> <img src="/uploads/219853/homemade-steady-rest-55.jpeg"/> </a> </div> </div> <div class="head pngfix"></div> <div class="left pngfix"></div> <div class="right pngfix"></div> <div class="blockover b1 pngfix"> <div class="title"> <a href="http://www.homemadetools.net/homemade-steady-rest-55">Steady Rest</a> <span> by <a href="http://www.homemadetools.net/builder/threesixesinarow_2">threesixesinarow</a></span> </div> <div class="tags">tags: <a href='http://www.homemadetools.net/tag/steady-rest'>steady rest</a> </div> </div> </div> </div>
