Coupon code for 20% off membership: SPRING20
Results 1 to 4 of 4
Thread: Unrolling sheetmetal coil up a structure - GIF
    Altair's Avatar
    Save 20% on Membership
  2. #2
    greenie's Avatar
    Dec 2018
    greenie's Tools
    Looks like they are 'roll forming' the roof iron, while it's up in the air.
    That would sure be a big money saver, instead of 'roll forming' it elsewhere in a factory and then transporting it to site.
  3. #3
    Supporting Member bob_3000's Avatar
    Aug 2020
    Quote Originally Posted by greenie View Post
    And they wonder why the roof departs in a windstorm..."WELL IT WAS NEVER LIKE THAT HERE BEFORE!"...
  4. #4
    You are correct the roof will be standing seam with clips bolted to the purlins and sealed between each roofing seam. Once a crimp sealed standing seam roof is installed you had better hope you started out straight and square because the only way to remove it is to cut it loose. The advantage of using standing seam is the panels can be made as long as needed, no need to have overlap connections. even if the panels happen to be 100s of feet long. the crimped seams mean no wind can raise the lap joints
  5. The Following 2 Users Say Thank You to Frank S For This Useful Post:
    greenie (Feb 4, 2023), Ralphxyz (Feb 7, 2023)
