Thread: Using Harbor Freight press with Swag brake in the way
    Supporting Member tmate3's Avatar
    Jan 2021
    tmate3's Tools
    I have found it obnoxious to give up my ability to use my 20 ton hydraulic press when it is occupied by my Swag finger brake. As useful as the brake is, it is tiresome to have to uninstall it every time the press is needed as a press.
    I'm currently fixing this problem. If you have a winch installed to raise and lower the deck, as I do, my fix is to lower the existing deck (table) way down, and fabricate a second deck from a length of channel. It can be quickly inserted above the brake in the frame and used for pressing. The second deck can be made as sturdy as necessary for the pressing you intend to do. Use a wooden block to raise the pressing surface as needed. I'm using 4" x 7.25 channel, which is in the process of being delivered. See drawing below:
  2. The Following 5 Users Say Thank You to tmate3 For This Useful Post:
    ductape (Feb 8, 2023), Jon (Feb 9, 2023), Scotty1 (Feb 6, 2023), wcfields1965 (Mar 12, 2023), WmRMeyers (Feb 6, 2023)
    Thanks tmate3! We've added your Swag Brake Deck to our Brakes and Presses category,
    as well as to your builder page: tmate3's Homemade Tools. Your receipt:
    Viny's Tools
    Great idea! I've been frustrated by that very issue. Thanks
    Dec 2022
    Midwest US
    ductape's Tools
    That is a great idea. Thanks!
    Jan 2021
    tmate3's Tools
    Here the 2nd table is installed in the press above the lowered Swag brake. Two of the height adjustment frame hole levels are still available above the brake. The 6x6 block of wood acts as a spacer, and adds stiffness if needed. The 18 lb. table can be removed and the brake raised for use in about 5 minutes time. The brake bolts to the frame in its raised position, which takes about 3 out of the 5 minutes.
    Using Harbor Freight press with Swag brake in the way-2nd-table.jpg Using Harbor Freight press with Swag brake in the way-spacer-block.jpg
  8. The Following User Says Thank You to tmate3 For This Useful Post:
    Viny (Feb 10, 2023)
