Results 1 to 8 of 8
Thread: Using the lathe like a shaper
    I needed to cut a 2 1/2" long keyway in a couple of 5/8 diameter shafts and I didn't have an end mill small enough for the task.
    So what I did was to lay a piece of HSS that I have ground for cutting groves on its side in the tool post and used the carriage wheel to cause the action of a scraper going back and forth.
    If projects like these are going to be on going I see a whole host of new tools I am going to have to make soon
  2. The Following 9 Users Say Thank You to Frank S For This Useful Post:
    baja (Oct 22, 2021), bruce.desertrat (Oct 21, 2021), Bullet500 (Oct 21, 2021), emu roo (Apr 23, 2025), Jon (Oct 28, 2021), lassab999 (Oct 22, 2021), mwmkravchenko (Oct 21, 2021), nova_robotics (Oct 21, 2021), Ralphxyz (Feb 2, 2024)
    Perth Ontario Canada
    Takes a while, but gets it done.
  4. The Following User Says Thank You to mwmkravchenko For This Useful Post:
    emu roo (Sep 16, 2025)
    Sep 2018
    nova_robotics's Tools
    Beauty. Plus now you'll have plausible deniability when people ask you why your right arm is so much more muscular than your left.
  6. The Following User Says Thank You to nova_robotics For This Useful Post:
    Actually the carriage wheel on my lathe is to the left side. Which is perfect for me I'm 60% left hand dominant this lets me do the cross slide feed with my right
    Sep 2018
    Mine too. It was a bad joke implying you were a chronic masturbator.
  10. The Following User Says Thank You to nova_robotics For This Useful Post:
  11. #6
    Thanks Frank S! We've added your Shaper to our Machining category,
  12. The Following User Says Thank You to DIYer For This Useful Post:
  13. #7
    Aug 2016
    wizard69's Tools
    Once it starts it never ends. When you find your self "just having to build a new shop" you will know that the bug has bitten hard.
  14. The Following User Says Thank You to wizard69 For This Useful Post:
  15. #8
    Quote Originally Posted by wizard69 View Post
    I already have plans in the mill to add another 6000 to 9000 sq ft. with the first part being a 30x 40 addition for metal storage
    Download plans for milling tools.
  16. The Following User Says Thank You to Frank S For This Useful Post:
