Thread: using multiple squares as a layout templet
    One of the helpful things I have is over a dozen framing squares. When I need to make repetitive layouts, I will sometimes clamp 2 ,3, 4, or as many as required in which ever layout shape I need. This way I do a layout once then use the squares for the reptations. Here is an example of using 3 squares for an equilateral triangular layout
    After marking it is a simple matter to position the rods where the circle and the points of the triangle converge
    A single layout templet made from the squares to reproduce half a dozen parts
  2. The Following 4 Users Say Thank You to Frank S For This Useful Post:
    emu roo (May 7, 2026), Floradawg (May 7, 2026), Philip Davies (May 16, 2026), thevillageinn (May 9, 2026)
    Oct 2019
    Australia
    Great thinking Frank S
