Thread: Using a steel rule for setting internal lathe tools on centre height.
    Berkshire UK
    thehomeengineer's Tools
    Hi All
    I just wanted to clarify the setup I use for setting internal lathe tools at centre height using the tangent of the stock and a steel rule.
    I simply move the tool to the opposite side of the workpiece and set the boring tool on the outer diameter, in the same way as the external tools. If using a boring bar, it is highly unlikely that you would be using a centre to support the work piece. The photo below shows the setup for internal tools.
    Using a steel rule for setting internal lathe tools on centre height.-img_0864.jpg
    Thank you again for viewing
    The Home Engineer
  2. The Following 4 Users Say Thank You to thehomeengineer For This Useful Post:
    LMMasterMariner (Feb 22, 2018), Paul Jones (Feb 26, 2018), PJs (Feb 24, 2018), Seedtick (Feb 23, 2018)
    Thanks thehomeengineer! We've added your Center Height Setup for Internal Lathe Tool to our Measuring and Marking category,
    Dec 2016
    Ralphxyz's Tools
    That makes perfect sense, thank you.
    Ralph
