Results 1 to 10 of 13
Thread: V Block with Clamps
    Jul 2014
    San DIEGO, California
    Captainleeward's Tools
    V Block with Clamps
    V Block with Clamps. Made from cold Rolled steel and square tubing.
    V Block with Clamps-005.jpgV Block with Clamps-006.jpgV Block with Clamps-007.jpgV Block with Clamps-008.jpgV Block with Clamps-009.jpg
  2. The Following 17 Users Say Thank You to Captainleeward For This Useful Post:
    asterix (Aug 21, 2022), Canobi (Dec 1, 2017), Captn Roy (Aug 15, 2018), chainsawd (Aug 21, 2022), emu roo (Oct 16, 2025), JRock (Apr 24, 2018), LMMasterMariner (Dec 2, 2017), Miloslav (Dec 7, 2018), mwmkravchenko (Sep 10, 2020), NortonDommi (Dec 1, 2017), Paul Jones (Dec 4, 2017), rayh__ (Aug 21, 2022), rossbotics (Dec 2, 2017), Seedtick (Dec 1, 2017), thehomeengineer (Apr 25, 2018), Tonyg (Dec 8, 2018), Tuomas (Dec 5, 2017)
    Jul 2014
    North Island, New Zealand.
    NortonDommi's Tools
    Far better clamps than the cast ones that come with many smaller V-blocks, thanks for reminding me that I need to make a few.
  4. The Following User Says Thank You to NortonDommi For This Useful Post:
    Jul 2014
    HI NortonDommi, Thanks for your comment I have often talked to New zealanders on the ham radio bands a few years back nice fellas.
  6. The Following 2 Users Say Thank You to Captainleeward For This Useful Post:
    emu roo (Oct 16, 2025), NortonDommi (Dec 2, 2017)
    Thanks Captainleeward! We've added your V Block and Clamps to our Workholding category,
    Dec 2013
    Florida
    rossbotics's Tools
    Looks good Capt.
    Good idea using the square tubing as a clamp, like the screws too
    Comments are always welcome
    Doug
  10. The Following User Says Thank You to rossbotics For This Useful Post:
  11. #6
    Jul 2014
    Thanks Doug.... :O)
  12. The Following User Says Thank You to Captainleeward For This Useful Post:
  13. #7
    Jul 2017
    Port Elizabet, SA
    garage nut's Tools
    Do not want to hi jack this tread, but need to make myself a set of "V" blocks.
    But before I redesign the wheel, what are the steps to machine the blocks?
    Will adapt sizes in order to utilize this idea for the clamps.
    Are the clamps narrow enough to leave enough space in those slots to clamp the V blocks using those slots on the sides?
  14. The Following User Says Thank You to garage nut For This Useful Post:
  15. #8
    Jul 2014
    Hi Garage Nut, Thank you for your interest in my V blocks.
    Disclaimer:
    Always be sure when working with machinery to be careful and follow all the safety rules during operations.
    If you feel unqualified get a skilled machinist to help you with the project.
    the measurement for the block will be determined by the internal size of your square tube.
    1. mark a center line on a squared block on three sides, using blue or red marker dye.
    2.mark a v shape 45* on the center line on the front and back .with the center line on the bottom of the v.
    3.on the top of the square, on the center line, drill 1/4 inch holes all along the line to remove as much metal as you can, staying inside the v lines on the front and back of the block.
    4. Mill on a 45* table to cut the rest of the metal away that you could not get with the drilling. Or use a hand file if you don't have a mill.
    5. The side slots are done in the same manner as above except marking a square instead of a v shape drill as required.
    6. Cut the square tubing twice on one side to what ever size you cut the slots on the side of the block and file to fit.
    the answer to your last question is yes.
    Note. you could use a end mill to cut the whole thing out but end mills are expensive so I use drill bits to save wear and tare on the end mills. Drill bits are cheep.
    Have fun and enjoy...Cap
    If you feel unqualified get a skilled machinist to help you with the project. at your own risk.
    :O)V Block with Clamps-ck-006.jpgV Block with Clamps-009.jpg
  16. The Following 3 Users Say Thank You to Captainleeward For This Useful Post:
    emu roo (Oct 16, 2025), garage nut (Dec 4, 2017), ncollar (Apr 24, 2018)
  17. #9
    Oct 2012
    Captain
    Love the V-block and the square tube made it extra special.
    Nelson
  18. The Following 2 Users Say Thank You to ncollar For This Useful Post:
    Captainleeward (Apr 24, 2018), emu roo (Oct 16, 2025)
  19. #10
    Aug 2016
    wizard69's Tools
    Another why didn't i think of that! Excellent idea here.
    Thanks for the post and the excellent workmanship. Those clamps look to be very robust.
  20. The Following User Says Thank You to wizard69 For This Useful Post:
