V Block with Clamps. Made from cold Rolled steel and square tubing.
Attachment 20753Attachment 20754Attachment 20755Attachment 20756Attachment 20757
Far better clamps than the cast ones that come with many smaller V-blocks, thanks for reminding me that I need to make a few.
HI NortonDommi, Thanks for your comment I have often talked to New zealanders on the ham radio bands a few years back nice fellas.
Thanks Captainleeward! We've added your V Block and Clamps to our Workholding category,
<div id="blocks"> <div class="block b1 pngfix"> <div class="bimg"> <div> <a href="http://www.homemadetools.net/homemade-v-block-and-clamps-2"> <img src="/uploads/207533/homemade-v-block-and-clamps-2.jpeg"/> </a> </div> </div> <div class="head pngfix"></div> <div class="left pngfix"></div> <div class="right pngfix"></div> <div class="blockover b1 pngfix"> <div class="title"> <a href="http://www.homemadetools.net/homemade-v-block-and-clamps-2">V Block and Clamps</a> <span> by <a href="http://www.homemadetools.net/builder/captainleeward">Captainleeward</a></span> </div> <div class="tags">tags: <a href='http://www.homemadetools.net/tag/v-block'>V-block</a> </div> </div> </div> </div>
Looks good Capt.
Good idea using the square tubing as a clamp, like the screws too
Thanks Doug.... :O)
Do not want to hi jack this tread, but need to make myself a set of "V" blocks.
But before I redesign the wheel, what are the steps to machine the blocks?
Will adapt sizes in order to utilize this idea for the clamps.
Are the clamps narrow enough to leave enough space in those slots to clamp the V blocks using those slots on the sides?
Hi Garage Nut, Thank you for your interest in my V blocks.
Disclaimer:
Always be sure when working with machinery to be careful and follow all the safety rules during operations.
If you feel unqualified get a skilled machinist to help you with the project.
the measurement for the block will be determined by the internal size of your square tube.
1. mark a center line on a squared block on three sides, using blue or red marker dye.
2.mark a v shape 45* on the center line on the front and back .with the center line on the bottom of the v.
3.on the top of the square, on the center line, drill 1/4 inch holes all along the line to remove as much metal as you can, staying inside the v lines on the front and back of the block.
4. Mill on a 45* table to cut the rest of the metal away that you could not get with the drilling. Or use a hand file if you don't have a mill.
5. The side slots are done in the same manner as above except marking a square instead of a v shape drill as required.
6. Cut the square tubing twice on one side to what ever size you cut the slots on the side of the block and file to fit.
the answer to your last question is yes.
Note. you could use a end mill to cut the whole thing out but end mills are expensive so I use drill bits to save wear and tare on the end mills. Drill bits are cheep.
Have fun and enjoy...Cap
If you feel unqualified get a skilled machinist to help you with the project. at your own risk.
:O)Attachment 20787Attachment 20788
Captain
Love the V-block and the square tube made it extra special.
Nelson
Another why didn't i think of that! Excellent idea here.
Thanks for the post and the excellent workmanship. Those clamps look to be very robust.
Hey Mr. Wizard Thanks for the kudos hoping you are having a great day where ever you are... CAp.
If you're going to make V-blocks, consider this style...
https://www.subtool.com/st/vb_precis...ee_blocks.html
so they can be laid on their side without interference from the clamp - very handy when drilling/tapping for two orthogonal setscrews, etc.. Also note that the clamps can be inverted to clamp small diameter pieces.
Making soft brass tips for the clamp screws will prevent marring finished workpieces. They can be permanently attached or removable.
What did you use for the set screw? Most of the V blocks I have have very weak screws that twist out of line.
Ralph
