Results 1 to 7 of 7
Thread: A Variable Height V Block
    Nov 2012
    Phoenix, AZ
    rgsparber's Tools
    I recently needed to align a part clamped to a block with some round stock held in a V block. In theory, shims could be used but this is a real pain in the a**. I wanted a way to adjust the altitude of the round stock in a continuous fashion. Here is what I slapped together:
    https://rick.sparber.org/VariableHeightV_Block.pdf
    Thanks,
    Rick
    Rick
  2. The Following 7 Users Say Thank You to rgsparber For This Useful Post:
    Altair (Jan 2, 2020), baja (Jan 4, 2020), Inner (Jan 6, 2020), Jon (Jan 3, 2020), mklotz (Jan 2, 2020), Seedtick (Jan 3, 2020), verticalmurph (Jan 3, 2020)
    Thanks rgsparber! We've added your Variable Height V-Block to our Miscellaneous category,
    Sep 2013
    Karl_H's Tools
    Nice, Rick.
    My first inclination (pun intended) would be to drill and tap perpendicular to the way you did. The V block would rest firmly on the angle bracket and the angle bracket would be supported by the entire lower corner on one side and the screw you drilled and tapped for on the other. Just my 2¢.
    Karl
    Sep 2013
    Karl_H's Tools
    This is what I had tried to express:
    With the added drawing, it is now my $1.02 worth!
  6. The Following 3 Users Say Thank You to Karl_H For This Useful Post:
    Inner (Jan 6, 2020), rgsparber (Jan 4, 2020), verticalmurph (Jan 5, 2020)
    Rick and Karl's methods are both excellent examples of a fundamental principle of tool design...
    Whenever you can identify a degree of freedom that is unneeded in your problem, that fact can be used to simplify the design or provide an opportunity for simplification, another capability, weight reduction or even artistic embellishment.
    This insight first struck me when I saw a picture of an old British stationary steam engine with the connecting rod between the eccentric and the steam valve made as an open-work frame rather than the traditional solid shaft. I came to realize that the "essence" of a connecting rod is its ability to hold two holes a fixed distance apart and the medium and shape that accomplished this was irrelevant.
  8. The Following User Says Thank You to mklotz For This Useful Post:
    jdurand's Tools
    In my early engineering classes we were taught tricks to simplify problems, like using a cable when all you need is tension or using hinges on support beams that "shouldn't" move. This removes having to include bending loads in your calculation. Cables are ALWAYS in tension only. Hinged parts are in tension or compression and nothing else (assuming your bridge isn't leaning sideways).
  10. The Following User Says Thank You to jdurand For This Useful Post:
  11. #7
    Nov 2012
    Phoenix, AZ
    rgsparber's Tools
    Quote Originally Posted by Karl_H View Post
Name:	Variable Height V Block Suggestion.png
    Karl’s brilliant idea is now in the article (with his permission). Thanks Karl
    Download plans for milling tools.
    Rick
  12. The Following User Says Thank You to rgsparber For This Useful Post:
    Karl_H (Jan 4, 2020)
