Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 25
Thread: Vegetable oil as a cutting oil for machining?
    Dec 2016
    bobs409's Tools
    Question Vegetable oil as a cutting oil for machining?
    I thought I'd give it a try today an it seemed to work good. (so far) The normal cutting oils make too much smoke so I got this idea. I used it today on the lathe with some 1018 steel and not a bit of smoke from this! It didn't even give off much smell at all.
    Would like to hear what others think about using this. Good? Bad?? What other things have you tried?
  2. #2
    Supporting Member smithdoor's Avatar
    Clovis CA
    I have read in machinist hand book using lard works good sell like bacon cooking
    The vegetable will work but may form a gum on your machine tool
    I do most my machining dry and only use oil for threading
    Dave
  3. The Following User Says Thank You to smithdoor For This Useful Post:
    bobs409 (Jan 19, 2017)
    Jul 2016
    If it works for you OK but it does tend to go gummy.
    Machine oil comes in many grades and is cheap enough so experiment with them, my lathe has a coolant system so I use sulpherised cutting oil. when I use a squeeze bottle I dilute it with kerosene this does not seem to hurt the cutting oil and it evaporates over a long period of time so mixing with the lathes coolant is not a problem so I use it as a general spray over all machine parts as a rust inhibitor.
    Apr 2013
    Wasilla, Alaska
    cutting oil substitutes
    Quote Originally Posted by tooly View Post
    At Westinghouse Nuclear Reactor Division, we used Crisco for all tapping in various grades of stainless steel, it held up better than anything else we found.
    Jun 2015
    Quote Originally Posted by smithdoor View Post
    Dave
    use unsalted lard for threading especially SS
    Bacon grease will have salt in it.(salt & moisture,RUST)
    veg oil not the same and smokes above 350* when machining. If it doesn't smoke,one is not using machines capabilities.
    Dec 2016
    bobs409's Tools
    Thanks for the suggestions. Mainly looking for something that doesn't produce all that smoke.
  8. #7
    Jun 2013
    I'm just a hobby machinist but ATF, automotive transmission oil, has worked well for me for years.
  9. #8
    Jul 2016
    Quote Originally Posted by Rockytime View Post
    Interesting you should say that I use automatic transmission oil on my milling machine, the main reason is that the coolant pump gives a better flow with the thinner oil,it is not as strong as my lathe pump.
    It seems to do the job OK some smoke on occasions but nothing I can"t live with.
    In general I have not noticed a lot of difference in performance between oils as a small workshop machinist. High speed CNC and production machines is a different call.
  10. #9
    Jun 2015
    Want no smoke, adjust speed/feed and depth of cut, till nothing smokes, this way one can turn a 15 min project into all afternoon.
  11. #10
    Oct 2016
    fandres's Tools
    I use chainsaw bar oil most of the time and it works well and is a lot cheaper than cutting oil $10 for a litre of bar oil compare to $50 for 500ml cutting oil.
