Page 3 of 3 FirstFirst 1 2 3
Results 21 to 25 of 25
Thread: Vegetable oil as a cutting oil for machining?
  1. #21
    Cutting Fluids; a 0.50 cent tour.
    Subject of much discussion, here and wherever metals are cut. There is science, primarily chemical and physical attributes that allow different selections to perform. No surprise, a lot of marketing/ salesmanship are at play too.
    These are arranged in mechanical order of; producing a chip, cooling the chip, expelling the chip, achieve and preserve surface finish, maintaining stable material temperature. Often, attaining just one of first four, or combination of three produces satisfactory results. The material in question, operation performed + speeds and feeds, and tool condition are a greater part of the equation.
    a] Friction is a product of machining. Primary effect is reduction of surface tension of material present when tool engages chip. The desired effect is a film on part and cutter to prevent chip welding itself to either. While termed 'lubricants' that is really secondary. Descriptions of lubrication/ friction/ heat overlook the mass of a bar vs the chip; temperature change of bar is minor compared to chip. Why motor and especially gear oils are poor cutting fluids; and worse yet to run engine on cutting oil!
    youtube.com/watch?v=4cykOPKpaTw add www. to the link; I'm just saving space, adding suspense. But 23 seconds in, it and my avatar are one, channeling as it were.
    b] Removal, absorption or separation of heat. Whether dripped, brushed, mist or flood, some better in heat control than fluids to improve cutting. At serious feed rates, blue chips all over the floor proves dry cutting can succeed. Sometimes all required is compressed air; nozzle and velocity lower relative temperature and flush chips very well. Introducing fluids produce the same effect; and an unintended shower for operator.
    c] Smaller particles can get pressed between workpiece and tool; sufficient heat will rebond them to workpiece. Certain materials have that tendency as well, where no speed + feed combo want to alleviate that. That is incorrectly diagnosed as poor finish. In reality, it's metallization occurring. Tool sharpness, height from centerline, setover, rotation vs travel direction, and lack of clearance contribute to that first. Rebonding is just evidence.
    In production environments, tests and history are results determining what occurs next time. Small shops more driven by availability and expense, and issues from exotic materials don't enter. Lard, vegetable oils, kerosene, bar oil, bee wax, soapy water; all work likely by producing a film with varied cooling rates. Tool conditions, operation performed, and machinability factors though are primary.
    d] Finally, material temperature. Heat expands material proportional to mass. The majority of HMT is not industrial sized projects; yet use industrial processes. i.e. Expecting hot weldment to run immediately in a lathe or drilling could be unreasonable, equivalent heat vs small project.
    300 stainless and free cutting brass run easily; where 316 [work hardens] or phosphor bronze/ copper alloys can be irritating.
    Then there are situations where heat is not primary in the same sense. All conditions have to be balanced.
    Low 1000's CRS is not all that machineable, you can get size yet finish can be problematic. Yet 12's and many tool steels and alloys are a dream to run.
    Aluminum same deal; low T's require razor sharp honed HSS and lower speeds than T5 & 6 plow it like mad with ease, mill T7 trying to guess what planet it comes from...an unnamed moon of Holimolithius?
    Most coolants are recoverable, even spray mist as in milling. Most mills have pipe threads in each end of table. Commonly; cans are suspended below for what flows out. I perforate a thin plastic container [like yogurt] as a separator. With holes pierced from outside wall, above the bottom, the 'barb' traps floating matter, and coolant flows through. Lathes have screens to accomplish separation. Grinding presents a problem in abrasive and micro-chips fouling pump vanes. Those are separated by dam-like arrangements with spillways, usually 3 and sump for pump. The 1st wall is notched high in the wall to force any kind of dense matter submerge. Successive walls are notched likewise but somewhat lower. Grinding typically uses water based emulsions and evaporates. You'll know by looking or when coolant flow slows to nothing, replace water and back to business.
    Last edited by Toolmaker51; Jan 22, 2017 at 07:22 PM. Reason: Was Camera! Lights! Action!, now that forgotten first go-round.
  2. The Following User Says Thank You to Toolmaker51 For This Useful Post:
    PJs (Jan 23, 2017)
  3. #22
    Supporting Member Ed ke6bnl's Avatar
    Mar 2012
    So. California high desert
    Ed ke6bnl's Tools
    I'm with you bobs409, that smoke is not good for the old lungs. I keep the garage door open when doing any kind of machining. Also have a small fan moving the air across the work.
    I also read about lard. My new wonder lube is Fluidfilm. Got turned on to it by a guy who did machine reconditioning most of his life. It's lanolin based and non toxic. Not tried for machining yet but everything else I've tried it on has been amazing.
    I have a gallon of their thick Fluidfilm and will have to try it out, I got it for rust protection and was ok not spectacular.
    1950 F1 street rod
    1949 F1 stock V8 flathead
    1948 F6 350 chevy/rest stock, no dump bed
    1953 chevy 3100 AD for 85 S10 frame going for a 4BT cummins motor, NV4500
    1968 Baha Bug with 2.2 ecotec motor, king coil-overs,P/S
    2000 National Sea Breeze 5th wheel trailer
    1998.5 Dodge 2500 4x4 Cummins,
  4. #23
    Supporting Member smithdoor's Avatar
    Clovis CA
    The down side to most dark cutting oils (AKA sulfur, minimal oil, lard and kerosene) is the smell and keeps the wife away.
    The upside dark cutting oils to does work well keeping mosquito and bugs away.
    FYI I was buying for shop 55 gal drums of oil two or three times a year. I even would one year Blender with transform oil to lower the cost.
    In my home shop today, I use a shop vac today and dry but I have look in to putting the shop vac outside the shop. The sound and any smoke will be gone to wind. The upside keeps the wife a lot closer today and the MD doctor happy too, avoid using dark cutting oil.
    So using vegetable cutting oil sound great
    Dave
  5. #24
    Supporting Member Hans Pearson's Avatar
    Jan 2017
    Quote Originally Posted by bobs409 View Post
    I thought I'd give it a try today an it seemed to work good. (so far) The normal cutting oils make too much smoke so I got this idea. I used it today on the lathe with some 1018 steel and not a bit of smoke from this! It didn't even give off much smell at all.
    Would like to hear what others think about using this. Good? Bad?? What other things have you tried?
    I also use a Silicone aerosol spray sold as Fuch Ecocut SC 14 here. Not too expenive and very convenient to use. I am sure there should be a similar product available where you are.
  6. #25
    Jan 2016
    Moby Duck's Tools
    Quote Originally Posted by smithdoor View Post
    Dave
    Transformer oil is expensive compared to regular cutting fluids. If you got it cheap it is probably because it was drained from transformers containing oil containing polychlorinated biphenyl's (PCB). This organic animal and environmental toxin was banned from new production in most countries in the 1970's but there are still lots of transformers containing PCB's out there, including some of the small bar shaped ones in fluorescent light fittings. Disposal of oil drained from these transformers, or disposal of sealed transformers, comes with a cost, and unscrupulous companies may sell the oil off cheap to unsuspecting customers. The use of transformer oil blended into regular cutting oil was not a good idea.
