Results 1 to 7 of 7
Thread: Vernier Scale for Homemade Milling Machine
    Jun 2020
    engineer steve's Tools
    Linear Scale for Homemade Milling Machine
    In this video I am installing a linear scale on my homemade milling machine.
  2. The Following 2 Users Say Thank You to engineer steve For This Useful Post:
    GedB (Apr 6, 2021), Jon (Apr 7, 2021)
    Stockholm, Sweden...
    DIYSwede's Tools
    -Did I miss something? You fitted a scale, all right - but no "sort Vernier" in the normal sense of the word,
    as there's no subsidiary scale as far as I could see...
    "A vernier scale is visual aid to take an accurate measurement reading
    between two graduation markings on a linear scale by using mechanical interpolation;
    thereby increasing resolution and reducing measurement uncertainty
    by using vernier acuity to reduce human estimation error."
    You can fit a subsidiary scale to easily get down to 1/20th of your scale graduation like:
    Might seem a bit picky - but I just can't stand hearing electronic calipers being called "Digital Verniers" any more...
    Cheers
    Johan
    Jun 2020
    I think you're right, going to change the title.
    DIYSwede's Tools
    No biggie- it wouln't be such a big deal for you to get yourself a real vernier after all.
    Wing some engraving facility on your mill: just bolt a small aluminum plate (subscale-to-be) to the table,
    put some engraving point/ scriber in the chuck and go.
    You could make the subscale to reach up to the 39th scale point (say in 10 divs with 1/2 sub-divs in between),
    so that it'll be real easy to read, minimize parallax, and it'll give good resolution down to 1/20 graduation.
    Two cents
    Johan
    Thanks engineer steve! We've added your Milling Machine Linear Scale to our Milling category,
    as well as to your builder page: engineer steve's Homemade Tools. Your receipt:
    MasterMaker's Avatar
    Aug 2012
    A sliding easy clamped/un-clamped mount of a regular digital caliper would be better......
  8. #7
    Jun 2020
    I know what you mean but that's not exactly what I am looking for. It's not similar to a dro but a visual aid for low accuracy work or layout-work.
