Get 500+ homemade tool plans, tool build guides, ebooks, and much more.
Page 2 of 2 FirstFirst 1 2
Results 11 to 15 of 15
Thread: Very powerful gearbox from wiper motor.
    Supporting Member manshands's Avatar
    Jun 2020
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    manshands's Tools
    Thank you so much! I am very glad that people like my projects. I will try to do interesting projects further.
    45 Best Harbor Freight Tool Modifications
  2. #12
    JoeH's Avatar
    Mar 2018
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    500+ Homemade Tool Plans
    I've been looking at this motor recently. Looks similar to the ones you guys have been talking about.
    https://www.amazon.com/Makermotor-Sh...5D9XSMS76RBJW3
    Forge Build Guide
  3. #13
    Stockholm, Sweden...
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    DIYSwede's Tools
    Quote Originally Posted by JoeH View Post
    Sure its similar - but smaller in size with a 50 max rpm and 60w continous output -
    the page doesn't say anything about the duty factor for higher outtakes.
    Its non-cheap price tag and "Makermotor" brand sounds to me like it's intended for the Arduino lot/ Robot making crowd.
    A (no-load) 50 rpm motor with 4,4 ft-lb starting torque will eventually get the jack up,
    but it'll take some time and probably complain a bit when the fully loaded scissor is at its bottom,
    where the screw, nut and its bearings is at its highest stress and the jack has its max lift/ turn.
    For the cost of this Makermotor alone you could get a 2 times as powerful, complete electric scissor jack at a FleaBay discount,
    but then you wouldn't have a DIY project...
    Added: Most 2,5 ton electric jacks available of FleaBay etc has a 100-120W motor and a 15 A fuse -
    giving a max momentary input power of 200 W.
    I've found none of these listing the full height & load lifting time (nor the motor's rpm),
    but a few reviews state "within a few minutes"...
    If you choose a low watt & lo rev DIY solution - there's simply a time penalty to pay for any given load,
    (if it'll work at all) as there's simply no free lunches here either.
    YMMV - Personally I'd rather visit the local scrap yard for a heavy duty hi-tork piece with 200-300-ish rpm for a mere 10 bucks.
    Cheers
    Johan
  4. #14
    Jun 2020
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    manshands's Tools
    I just wanted the motor to work 12 Volts, and not from 24 volts, since the car has only such a voltage.
    I found
    https://aliexpress.com/item/4000061085442.html
    it has a power of 100 watts, but it is also 24 volts.
    According to your advice, tomorrow I’ll go to the warehouse of old cars, try to find a motor there.
  5. #15
    Jun 2020
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    manshands's Tools
    Using this gearbox from the angle grinder and the wiper motor, i began manufacturing a small winch for lifting a motor boat ashore. I hope to post a new video with the tests soon.
    Post your reply!
    eBooks for Supporters
