Results 1 to 10 of 10
Thread: Vice Buddy
    Dec 2016
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    bobs409's Tools
    Vice Buddy
    I'm calling this a "Vice Buddy." This simply supports long heavy items in a bench vise. No more looking for things to prop under that work piece!
    What makes this interesting is the wedge shape designed post. A locking bolt pushes a moveable plate and wedges against the post so it cannot slip downward. Just a light touch is all that's needed, no cranking down of the bolt. I didn't invent this design, I saw this on another tool and incorporated it into this.
    This can attach to your workbench with screws or with a C clamp. To make the tapered post, I took a piece of square tube and cut a taper down it lengthwise. Then I capped it with a piece of metal and welded it.
    Vice Buddy-1.jpgVice Buddy-2.jpgVice Buddy-3.jpgVice Buddy-4.jpgVice Buddy-5.jpgVice Buddy-6.jpgVice Buddy-7.jpg
  2. The Following 17 Users Say Thank You to bobs409 For This Useful Post:
    Andyt (01-22-2020), baja (01-22-2020), Crusty (01-21-2020), DIYer (01-21-2020), Drew1966 (01-21-2020), Inner (01-21-2020), Jon (01-21-2020), Karl_H (01-25-2020), Little Rabbit (01-21-2020), Rangi (01-25-2020), rdarrylb (01-21-2020), Savage11 (01-21-2020), Scotsman Hosie (01-26-2020), strube1369 (01-23-2020), thehomeengineer (01-21-2020), verticalmurph (01-21-2020), yester145 (01-26-2020)
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thanks bobs409! We've added your Workbench Vise Rest to our Workholding category,
    as well as to your builder page: bobs409's Homemade Tools. Your receipt:
    bobs409 (01-21-2020)
    Oct 2016
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Nice. Simple. Elegant
  6. The Following User Says Thank You to Drew1966 For This Useful Post:
    mlochala's Avatar
    Nov 2012
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    mlochala's Tools
    Excellent idea. Thanks for sharing!
  8. The Following User Says Thank You to mlochala For This Useful Post:
    bobs409 (01-22-2020)
    Oct 2019
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Great simiple shop tool. Will be building one
  10. The Following User Says Thank You to lynn48 For This Useful Post:
  11. #6
    Mentioned
    0 Post(s)
    Tagged
    5 Thread(s)
    Congratulations bobs409 - your Workbench Vise Rest is the Homemade Tool of the Week!
    This is a clever and extremely useful tool that I'm sure many other guys around here will be building.
    Mobile Gantry Crane by barts metalwork
    Electro Hydraulic Jack by Mr.DK DIY
    Pulley Key Remover by thehomeengineer
    Belt Grinder Flat Platen by celsoari
    Magnetic Stirrer by Salix84
    Container Slide Pads by Frank S
    Coal Forge by Savage11
    Mini Press Brake by jonlegrand1
    Lathe Drive by tonyfoale
    Gas Cylinder Caddy by bobs409
    Universal Vise by Tek12h
    Tubing Profiler by Kovanca Polock
    Lathe Grinder Mount by bouboulas
    Seal Puller by nicky1
    Circular Saw Guide by Didpoolhall
    Gasket Cutter by jdurand
    Voltage Tester by brnjh1
    Air Compressor by Vyacheslav.Nevolya
    Compass by RCTURKA
    bobs409 - you'll be receiving a $25 online gift card, in your choice of Amazon, PayPal, or bitcoin. Please PM me your current email address and gift card choice and I'll get it sent over right away.
    More importantly, this is your 5th Homemade Tool of the Week win! I've just added the silver wrench-on-pedestal graphic to the awards showcase in your postbit, visible underneath your avatar.
    Great job, and you're in excellent company joining these other 5-time winners: rgsparber, rossbotics, Christophe Mineau, Brendon, Frank S, mklotz, Vyacheslav.Nevolya, brianhw, LMMasterMariner, Tuomas, olderdan, tonyfoale, thehomeengineer, and Stevohdee.
    Here are all of your Homemade Tool of the Week winning tools. Congrats again
  12. #7
    Dec 2016
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    bobs409's Tools
    WOW! Thank you Jon! It's really nice to have such a great place to show some of my creations.
  13. #8
    Jul 2019
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Good idea. I use two vices, one at either end of the bench which means you can support or work on either end of the job but if you don’t have a second vice then with respect I think this is the next best thing. If you are thinking of using two vices they don’t need to be the same size just ensure that the rear or fixed jaw on both vices are exactly in line with each other. A simple string line will do it nicely. Cheers Stuart.
  14. The Following User Says Thank You to Scrounga For This Useful Post:
    bobs409 (01-25-2020)
  15. #9
    Skun Knuckles's Avatar
    Dec 2017
    Gippsland Victoria Australia
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    The taper design is a brilliant idea,that I will be adapting to the floor stand that I use for supporting long material in the drill press.
  16. The Following User Says Thank You to Skun Knuckles For This Useful Post:
    bobs409 (01-26-2020)
  17. #10
    Dec 2018
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    thinkbackwards's Tools
    Thanks that's brilliant. Thnk I'll add a toggle clamp on the side to fasten it to the work bench quickly and easy horizontal adjustment.
    Post your reply!
    eBooks for Supporters
  18. The Following User Says Thank You to thinkbackwards For This Useful Post:
    bobs409 (01-31-2020)
