Results 1 to 10 of 11
Thread: Wall mounted plier rack
    Jyväskylä Finland
    Tuomas's Tools
    Plier / handled tool rack.
    Another simple tool storage solution.
    Wall mounted plier rack. Easy to use and see the sort of the plier, without taking much space. Fits for different sized pliers.
    Frame is made from stainless steel sheet and pipes.
    Keyholes for mounting are made with die grinder.
  2. The Following 9 Users Say Thank You to Tuomas For This Useful Post:
    Baddog (Jun 11, 2021), baja (Jun 11, 2021), drivermark (Jun 12, 2021), Duke_of_URL (Jun 11, 2021), enginepaul1 (Yesterday), Frank S (Jun 10, 2021), glenng1982 (Jun 10, 2021), rebuilder1954 (Jun 11, 2021), Toolmaker51 (Jun 11, 2021)
    Another great build.
    Pliers, screwdrivers, combination wrenches, grinders, and C" clamps all need to have their own rack to hang from
    I like having my angle grinders on the wall as well
    But pliers will clutter up a tool box drawer worse than just about anything else the one you need is always on the bottom of the pile and every one of them above it will decide to open the handles when you try to close or open the drawer
    Thanks Tuomas! We've added your Pliers Rack to our Racks category,
    Jyväskylä Finland
    Tuomas's Tools
    Thanks Frank.
    Yep, that was what i used so far. Never found the one i needed.
    PS. End parts are easier to make using angle iron. I just didn't had suitable sized available, so i used what i had.
    Tuomas many of us could or should write books on using what we had. In a way we all are doing just that each and every time we post our creations on these forum's
    Baddog's Avatar
    Jun 2017
    Baddog's Tools
    Very nice.
    I've got a similar arrangement on the side of my welder/plasma cart for c-clamps and vise grips. Another like it on my grinder cart for angle grinders (hook arbor behind wheel over over top bar). Very handy as a general idea.
  8. #7
    Jyväskylä Finland
    Tuomas's Tools
    Quote Originally Posted by Baddog View Post
    Very nice.
    Thanks. Yep, same idea can be used in many different tools.
    I made this for clamps.
    Diy 20 ton hydraulic bench top press
    I like to have couple different clamps always near.
    Usually you need one " fast ", then its good to have couple near you.
    Other clamps i keep in drawer. When i need many, that's usually predictable, and i can take them near before i start building.
  9. The Following User Says Thank You to Tuomas For This Useful Post:
  10. #8
    Jyväskylä Finland
    Tuomas's Tools
    Yep. That's right. Sharing the idea is what matters.
  11. #9
    bruce.desertrat's Tools
    I have an old bicycle wheel screwed to a rafter over my bench with F-clamps and spring clamps hanging from it. Nearby but out of the way. Wall mounted plier rack-clamps.jpg
    If I"m not lazy and hang all the heavy ones on one side it turns quite easily to get at the various ones as needed.
  12. The Following 2 Users Say Thank You to bruce.desertrat For This Useful Post:
    enginepaul1 (Yesterday), Tuomas (Jun 11, 2021)
  13. #10
    Aug 2016
    wizard69's Tools
    Thanks for another great post!
    As for your materials, when I first looked I literally thought you had drilled holes in repurposed machine tool door handles. I suspect that there are lots of ways to accomplish the same results. A guy might even use wood��
    By the way, what you are able to create with an angle grinder is inspirational.
    Thanks Frank.
