Results 1 to 10 of 14
Thread: Wasp nest removal fail - video
  2. The Following 8 Users Say Thank You to Jon For This Useful Post:
    Andyt (Dec 25, 2019), carloski (Nov 5, 2022), emu roo (Mar 18, 2026), harleyron74 (Dec 24, 2019), high-side (Dec 25, 2019), Scotty12 (Dec 30, 2019), Seedtick (Dec 24, 2019), Tule (Dec 25, 2019)
    Jan 2014
    You could get by with that trick IF you did it very early in the morning when it is still dark and the wasps/hornets are still all in the nest. A better plastic bag would also be advised!!
  4. The Following User Says Thank You to harleyron74 For This Useful Post:
    of course they don't exist any more but a cloth flour sack with a heavy shot of starting fluid inside would do the trick
  6. The Following 3 Users Say Thank You to Frank S For This Useful Post:
    emu roo (Mar 18, 2026), Scotty12 (Dec 30, 2019), that_other_guy (Oct 31, 2022)
    Supporting Member thevillageinn's Avatar
    Jul 2017
    thevillageinn's Tools
    I've also heard of a hornet nest being removed not long after dark in a plastic bag, but by first adding a cotton ball into the opening, then bagging for removal. Type of bag, unknown.
  8. The Following User Says Thank You to thevillageinn For This Useful Post:
    Supporting Member Fluffle-Valve's Avatar
    Oct 2015
    Duston, Northampton, UK
    We all could see what was coming there. What a muppet.
    I have a 1972 Land Rover Series III Truck Cab/Pick-Up and a 1962 Land Rover Series 2a Carawagon Camper.
  10. The Following 2 Users Say Thank You to Fluffle-Valve For This Useful Post:
    emu roo (Mar 18, 2026), will52100 (Jan 1, 2020)
  11. #6
    He would have been better off with a wet bath towel and not have fooled around posing for the camera
  13. #7
    Quest for Viral Content seems to outrank Judgement, Feasibility, or mere Common Knowledge. I hope the income dribbles in fast enough to drown out neighbors laughter.
  14. The Following User Says Thank You to Toolmaker51 For This Useful Post:
  15. #8
    jdurand's Tools
    For yellow jacket in ground nests I've found going out at oh-dark-hundred when they're asleep, then stuffing moth balls in the hole and covering with a rock works well. It fills their tunnels with toxic fumes before they can dig their way out.
  16. The Following User Says Thank You to jdurand For This Useful Post:
  17. #9
    Dry Gulch, Tx
    Crusty's Tools
    Moth balls eh? I'll have to try that because it sounds much easier than the lawnmower exhaust into an overturned washtub approach that I've used for some time.
    My favorite pest removal though is still a good quantity of molten aluminum poured down a fire ant mound. It's satisfying and sometimes makes art when cool.
  18. The Following User Says Thank You to Crusty For This Useful Post:
  19. #10
    Stockholm, Sweden...
    DIYSwede's Tools
    A generous spray of brake cleaner, starting fluid or any such solvent into the nest's entrance
    a few hours after sunset usually does the trick. Remove the day after.
    Solvent fumes put them to sleep pretty quick.
    I've later used a 3 gal metal paint bucket with a little paint thinner to quickly rake the nest into,
    then cover for half an hour, pour out doused content and set afire. Really gross to watch it.
    I've never got stung - yet.
  20. The Following User Says Thank You to DIYSwede For This Useful Post:
