Results 1 to 9 of 9
Thread: Water main bursts in plumber's face - GIF
    nova_robotics (Oct 31, 2023)
    Sep 2013
    Karl_H's Tools
    Another case of the cameraman missing the money shot!
    Mar 2018
    Hoosiersmoker's Tools
    I wonder what shot into his face along with the water?
    "The man who views the world at 50 the same as he did at 20 has wasted 30 years of his life."
    - Muhammad Ali
  5. The Following User Says Thank You to Hoosiersmoker For This Useful Post:
    mwmkravchenko (Nov 1, 2023)
    Perth Ontario Canada
    What did this genius expect to happen? Or maybe this was a setup by the other guys. I hope he was wearing eye protection.
    Mark
    Aug 2019
    Oregon, USA
    BuffaloJohn's Tools
    They have special tools to do this kind of work and it is not a cordless drill with a hole saw...
    The money shot is there, it just goes by fast. If you go to 0:04 and stop the video, you can slowly step forward by pressing your cursor just ahead of the dot which is the current position.
  8. The Following 2 Users Say Thank You to BuffaloJohn For This Useful Post:
    Karl_H (Nov 1, 2023), mwmkravchenko (Nov 1, 2023)
    Supporting Member drivermark's Avatar
    Oregon City, Or. USA
    1. On the bright side, it wasn't a sewer pipe.
    2. Why would anyone be cutting into a live water main like that?
    I mean wouldn't you shut it off and relieve the internal pressure before cutting? Just curious.
  10. #7
    WmRMeyers's Avatar
    Dec 2014
    WmRMeyers's Tools
    Quote Originally Posted by drivermark View Post
    Amateur hour right there.
  11. #8
    Aug 2019
    Oregon, USA
    BuffaloJohn's Tools
    2 - Actually they cut into fully live pipes like that all the time. There is a special saddle they put on the pipe. There is a special fitting that is a combination of drill, fitting, and coupling that are part of the assembly. You make the hole into the larger pipe and it is capped auto-magically... You hitch up the tap pipe and remove the saddle assembly, all without making a mess. I have watched the tapping of PVC and asbestos concrete pipe for the water system my house is attached to.
    All this was done, in each case, without depressurizing the main. Main was about 110psi, 6" to 8" (depending on the job and branch). Barely a drop spilled...
  12. The Following User Says Thank You to BuffaloJohn For This Useful Post:
    mwmkravchenko (Nov 5, 2023)
  13. #9
    Quote Originally Posted by BuffaloJohn View Post
    Its even done on large high pressure live natural gas pipelines. You might think it is crazy, but a welder will weld a collar or a flanged coupling to the pipeline then a valve is mounted and the special penetrating device makes the hole in the main pipe.
