Weld test gone wrong.
Accidentally welding your head in between a railing - GIF
Bowling ball welding table - video
Mobile phone welding face shield - GIF
Welded Celtic knot
Welded Celtic knot
New plans added on 01/22/2025: Click here for 2,714 plans for homemade tools.
Nothing has gone wrong so far in that gif. the removal of the slag was a perfect release on a vertical weld. only by cutting the coupons and subjecting the weld to a bend test will show if there is any fault in the weld. examining a cross section of the cut will show the penetration. bending will either break the weld in the center or separate it from one plate or the other or if the weld is strong enough both plates will bend eventually the weld will be broken or the base metal of the plates will be torn apart at the edge of the heat effected zone.
KustomsbyKent (Dec 8, 2024)
Nothing went wrong except for a lack of comprehension on the part of whomever labelled the pic. He obviously had no idea what he was looking at.
I don't think it is a lie as much as someone not knowing what they are seeing. The is acrually how slag is supposed to come off a weld. It is just that a lot of people are not proficient enough do make it happen like that.
This is how slag should pop off. Even when stick welding. This is SAW welding. But the slag ideally would come off like this.
https://www.youtube.com/shorts/_jns6XG6fE4
