Results 1 to 7 of 7
Thread: Welder & Plasma cutter cart
    bobs409's Avatar
    Dec 2016
    bobs409's Tools
    Today I finished up the new welder cart I've been building. Got tired of using the rickety old Harbor Freight cart I had so I designed this one to meet my needs. It holds a mig welder and plasma cutter as well as an 80lb tank of C25 gas. I even tucked in a small inverter stick welder I have. A small plastic tool box on bottom rear shelf holds the consumables for both machines. Lots of hand made hooks for all the wires and leads.
    This is constructed of 1-1/4 16ga square steel tube for the main frame, 1" 16ga square tube for the handles and expanded metal for the shelves and back panels.
    A neat option about this cart most won't notice right away is that it rolls on 4 wheels for smooth surfaces or you can tip it back like a hand truck to roll on the large pnuematic tires for "rough terrain" like my yard. lol The machines and tank are securely mounted so they won't fall off or move during travel.
    The square tube/expanded metal theme was carried over from the welding table I recently made but a color change was made and choosing it was the hardest part!
    Welder & Plasma cutter cart-dscn2960.jpgWelder & Plasma cutter cart-dscn2959.jpgWelder & Plasma cutter cart-dscn2958.jpgWelder & Plasma cutter cart-dscn2957.jpgWelder & Plasma cutter cart-dscn2961.jpgWelder & Plasma cutter cart-dscn2962.jpgWelder & Plasma cutter cart-dscn2954.jpgWelder & Plasma cutter cart-dscn2956.jpg
  2. The Following 7 Users Say Thank You to bobs409 For This Useful Post:
    baja (08-22-2019), bruce.desertrat (08-21-2019), Christofix (08-23-2019), HandymanNSons (08-26-2019), Jon (08-20-2019), Rangi (08-22-2019), Sprig1 (08-21-2019)
    Content Editor DIYer's Avatar
    Thanks bobs409! We've added your Plasma and Welding Cart to our Storage and Organization category,
    as well as to your builder page: bobs409's Homemade Tools. Your receipt:
    Fluffle-Valve's Avatar
    Oct 2015
    Duston, Northampton, UK
    That looks like a work of art.
    Looks well thought out, but then you knew what you wanted and built it to the picture in your head.
    Well done matey. Top Marks. I like it.
    I have a 1972 Land Rover Series III Truck Cab/Pick-Up and a 1962 Land Rover Series 2a Carawagon Camper.
  5. The Following User Says Thank You to Fluffle-Valve For This Useful Post:
    bobs409 (08-22-2019)
    Oct 2015
    In picture 1. What is that you've left sitting on the Brake Drum?
    bobs409's Avatar
    Dec 2016
    bobs409's Tools
    Quote Originally Posted by Fluffle-Valve View Post
    That's an 87 Jeep YJ wrangler but it's not on the drum. There are blocks behind, it's sitting on the lower shock mount.
    Doing some typical rusty frame repair.
    Oct 2015
    Quote Originally Posted by bobs409 View Post
    Sorry, I meant the thing that is on top of the brake drum. You have left something on the brake drum. In picture 1.
  9. #7
    bobs409's Avatar
    Dec 2016
    bobs409's Tools
    Ah, that's just the case for my camera. I set that down everywhere!
    Post your reply!
