Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 21
Thread: WELDING FAILS!
    Supporting Member machining 4 all's Avatar
    May 2020
    machining 4 all's Tools
    WELDING FAILS!
    Today I put a smile on your face!
  2. The Following 10 Users Say Thank You to machining 4 all For This Useful Post:
    emu roo (Dec 12, 2025), EnginePaul (Jan 8, 2021), Jon (Jan 9, 2021), madmick77 (Jan 9, 2021), Philip Davies (Jan 10, 2021), Scotty1 (Jan 8, 2021), Slim-123 (Jan 9, 2021), sossol (Jan 8, 2021), TheElderBrother (Jan 8, 2021), Tonyg (Jan 11, 2021)
    Lake Tahoe
    IntheGroove's Tools
    At first glance I thought I read Wedding Fails. The only wedding fail is "I do." Anyway, if you are going to weld a skeg on an outdrive, remove it from the boat and drain the oil...
  4. The Following 2 Users Say Thank You to IntheGroove For This Useful Post:
    emu roo (Dec 12, 2025), NortonDommi (Jan 9, 2021)
    meyer77's Avatar
    Feb 2019
    meyer77's Tools
    I was on a job once and the guy installing a hand made metal hand rail was welding without a helmet (he did have one with him). I said "Don't you have a helmet?"
    He said "yea but I'm use to it"!
  6. The Following User Says Thank You to meyer77 For This Useful Post:
    May 2020
    "I'm used to it" is a bad excuse to go blind ... The arc emits visible and invisible light radiation, in practically all wavelengths! So, just use a suitable mask, to get a minimum protection, and no lame excuses...
  8. The Following User Says Thank You to machining 4 all For This Useful Post:
    Lake Tahoe
    IntheGroove's Tools
    I got flash burn once. Once...
  10. #6
    May 2020
    Eyes burned by welding look like a cart full of sand...
  11. The Following 2 Users Say Thank You to machining 4 all For This Useful Post:
  12. #7
    meyer77's Avatar
    Feb 2019
    meyer77's Tools
    Quote Originally Posted by machining 4 all View Post
    He was a little odd to begin with, I was setting marble on the first floor, he was welding above me dropping sparks and slag onto the new marble!
  13. The Following User Says Thank You to meyer77 For This Useful Post:
  14. #8
    May 2020
    Unfortunately this is not the profile of a good professional! All coating and finishing must be protected from welding spatter...
  15. The Following User Says Thank You to machining 4 all For This Useful Post:
  16. #9
    Aug 2012
    Australia
    desbromilow's Tools
    just me, or does the person pulling the Tig welder helmet off in #8 seem like the "fail" should be horseplay in the work place?
    Whilst the welder didn't have screens up, he was using his hand for a wind block, and was wearing correct PPE - signage should have been enough for observers to be protected - but some numbnut lifting my helmet whilst I'm welding would be considered as horseplay or worse.
  17. The Following User Says Thank You to desbromilow For This Useful Post:
  18. #10
    Jun 2019
    #1 no farting!!!
    Admittedly Have set fire to the cuff of my work pants. Saw this reflection inside my viser. From an early age my father taught me to wear welding gloves . "Its not to protect your hands son, its to put out the fire when u set yourself alight".
  19. The Following 2 Users Say Thank You to jatt For This Useful Post:
    emu roo (Dec 12, 2025), that_other_guy (Jan 17, 2021)
