Results 1 to 8 of 8
Thread: What the hell has happened to this hammer
    Supporting Member GabrielR's Avatar
    Feb 2019
    Estonia
    GabrielR's Tools
    Barn find. Would it be good to know what has been done with her? I think he has been used as a wedge for cutting stones but did not go quite well ...
  2. The Following 5 Users Say Thank You to GabrielR For This Useful Post:
    baja (Apr 27, 2019), Frank S (Apr 26, 2019), greyhoundollie (Apr 26, 2019), Scotsman Hosie (Apr 28, 2019), Seedtick (Apr 26, 2019)
    My SWAG...
    Is it possible that it's not a hammer but rather a handled wedge? The angled hole for the handle to make it more comfortable for a helper to hold the wedge in position while his buddy strikes the end opposite the wedge with a sledge. Perhaps used in metal forging work?
  4. The Following 2 Users Say Thank You to mklotz For This Useful Post:
    bigtrev8xl (Apr 29, 2019), Scotsman Hosie (Apr 28, 2019)
    Aug 2018
    Maybe it is an OFFSET hammer for driving railroad spikes. In a 3 or 4 man "gandy dancer" crew, it depends where you are standing in the circle around the spike being driven as to which angle you have to strike the spike without your hammer hitting the rail.
  6. The Following 3 Users Say Thank You to greyhoundollie For This Useful Post:
    Jon (Apr 26, 2019), Moby Duck (Apr 27, 2019), Seedtick (Apr 26, 2019)
    Quote Originally Posted by greyhoundollie View Post
    Gandy dancer, had no idea. Thanks. Lots more here: https://en.wikipedia.org/wiki/Gandy_dancer
  8. The Following 2 Users Say Thank You to Jon For This Useful Post:
    Alan Purdy (Apr 27, 2019), Scotsman Hosie (Apr 28, 2019)
    Marion, Iowa
    metric_taper's Tools
    I'm thinking this hammer was damaged by some use as pin or wedge. There is a crack that developed from the stretching of the material in the inside hole where the handle would be.
  10. #6
    A badly abused cross peen hammer probably use just as was previously stated as a wedge, quite possibly as a splitting wedge until the handle finally gave up the ghost then used without a handle even after the slug in the eye crumbled out, Once the eye began deforming it would be very hard to get a straight hit on it. So very likely the hammer head was non tempered and only moderately hardened the eye may have failed in one final hard striking blow
  11. #7
    Jul 2016
    I have seen similar destruction of axe heads used as wedges for splitting fire wood. There is simply not enough metal around the eye to take a beating. Heads like this that are used by striking with a sledge in blacksmithing usually have heavy walled eye's to prevent distortion like this.
    Eric
  12. #8
    Jul 2016
    As terminology comes back to me....
    Looks like a cross peen hammer abused as a fuller.
    Eric
  13. The Following User Says Thank You to suther51 For This Useful Post:
