OK, here's one for you guys...
The finish and size suggests a medical tool of some sort to me.
Good call.
It's an emasculator.
After the testis and the spermatic cord are excised from the scrotum the cord is crushed using the clamp operated by the upper lever. A convenient ratchet allows the operator to maintain clamping pressure without tiring his hands. We're told that crushing the cord minimizes bleeding and speeds healing (Yeah, I don't want to think about it either.).
After sufficient crushing, operating the lower handle pivots the curved knife downward and severs the cord and frees the testis.
I should point out that most barnyard emasculations are done using only a local anesthetic to dull the pain of the scrotal incision needed to gain access to the cord and testis.
Unusual, but still interesting. However, I must say that if anyone is considering this surgical procedure for himself, you might change your mind after seeing the Wikipedia page: https://en.wikipedia.org/wiki/Emasculator
Chuckle.
I do believe it's done a bit differently on humans. (Although you really don't want to know about the Chinese method for producing the eunuchs who ran the empire.) The procedure for producing operatic castrati was far less invasive. The last castrato died in the early part of the 20th century.
Way too much information guys...I'll be wincing for a week. :p
You mentioned it didn't you! It rang a past life bell of an acquaintance named Vlad...And you got me...I looked! Perhaps treppanning should be brought back for political daemon relief, with a side of Judas cradle for those really stubborn daemons.
Here is a quick modern tool I researched a while back. A hint...840nm.
Attachment 16340 Attachment 16341
I limit my singing to the shower; as non-operatic possible.
I did my bit with one testis set free in 1998.
No political perspirations, inspirations, or aspirations. Though, distributing a sprinkle of asphyxiations IS in order.
And, I limit trepanning to the engine lathe for O-ring grooves and flat gaskets.
Gave up proctoring when I finished in the Navy. Nobody taking exams, no need to monitor!
So I'm good, whatever the 840nm lens is. I'm inferial!
