Coupon code for 40% off membership: SUMMER24
Results 1 to 10 of 10
Thread: Wheel spanner - GIF
    biggist (May 19, 2024)
    Sep 2013
    Karl_H's Tools
    I don't see any advantage over the standard 4 way lug wrench.
    Aug 2019
    Oregon, USA
    BuffaloJohn's Tools
    Quote Originally Posted by Karl_H View Post
    It's not as big a storage size...
    Here is the product:
    https://www.walmart.com/ip/Kings-Cou...izes/941399396 $65.95
    https://garrettwade.com/product/geared-lug-nut-remover $68.90
    https://www.amazon.com/Kings-County-.../dp/B07R4GB4RP $89.95
    Aug 2021
    albertq's Tools
    Needs little effort to undo and tighten nuts as its geared down and torqued against the other nut. Ideal for women drivers too. A neat idea.
  6. The Following User Says Thank You to albertq For This Useful Post:
    Karl_H (May 19, 2024)
    Oct 2012
    Lafayette, Indiana
    sossol's Tools
    It has gear reduction via a planetary gearset. Something like 4:1 ratio. It's only meant to loosen the lug nuts. Once they're loose a regular lug wrench is used.
    Neil
  8. The Following User Says Thank You to sossol For This Useful Post:
    Oct 2012
    Lafayette, Indiana
    sossol's Tools
    I bought one of these off ebay back when it was mostly used items. I'd never seen such a thing before and I dig clever novelty tools, so had to have it. It's like new, well-made, looks really cool, came with a zippered nylon bag, and I'll never actually use it. Why? Because the case is thin cast aluminum. It may be fine under load, but cast aluminum can get a bit explody. Someday I might get brave enough to try it in a real-life scenario.
    Neil
  10. The Following User Says Thank You to sossol For This Useful Post:
  11. #7
    Aug 2019
    Oregon, USA
    BuffaloJohn's Tools
    Quote Originally Posted by sossol View Post
    Actually, this one has a 15:1 ratio
  12. The Following User Says Thank You to BuffaloJohn For This Useful Post:
    nova_robotics (May 20, 2024)
  13. #8
    When changing the tires on a M35 duce & a half you needed this puppy the inner tube held the square inner nut while the outer geared tube loosened the outer nut
  14. #9
    Sep 2018
    nova_robotics's Tools
    I was looking at buying one of these torque multipliers for my girlfriend last Christmas. She doesn't have enough upper body strength or weight to get lugs broken loose. I got her a 24" breaker bar instead, but she still has to jump on it.
  15. The Following User Says Thank You to nova_robotics For This Useful Post:
    Karl_H (May 20, 2024)
  16. #10
    Oct 2012
    Lafayette, Indiana
    sossol's Tools
    The breaker bar could serve as better a defensive weapon than the torque multiplier.
    Neil
  17. The Following 2 Users Say Thank You to sossol For This Useful Post:
    BuffaloJohn (May 20, 2024), Frank S (May 21, 2024)
